Streamline on rpi2
Has anyone tried to run DS-5 Streamline on Raspberry Pi 2?
I've managed to build gator daemon and driver against kernel with all required options enabled. However, when I try to start data capture I get following message:
ARM Processor PMU event counters have been detected, however the event counters are reading zeroes. Event counters include those counters listed in the counter configuration options dialog under the core name but exclude the cycle counter (Clock:Cycles) as it is controlled by a dedicated counter. It is possible that the PMU configuration bit DBGEN has not been enabled, and counter values subsequently will always read as zero. To remedy, please update your firmware or Linux kernel to enable DBGEN.
All suggestions appreciated.
br
MS
