keil compiler
Note: This was originally posted on 7th September 2009 at http://forums.arm.com
six month before i used Keil Arm compiler. In that compiler there are three option for code generation.
1.Keil ARm Compiler
2.Real View Compiler
3.GNU Compiler      from that i used the Keil ARM compiler. My codes are properly worked in hardware. But now i use new Keil Arm compiler. In this software they give two option only
1.Real view Compiler
2.GNU compiler
from that i use the Real view compiler. The codes are working properly in simulation. But the codes are does not executed in hardware
  • Note: This was originally posted on 8th September 2009 at http://forums.arm.com
    From memory, when Keil was an independant company they developed their own compiler.  Since the merger with ARM that has disppeared, and the recent versions have come with RVCT.
    How does it fail in hardware?  What hardware are you using?
    i purchased one arm evaluation borad. In that board old vesrions codes are executed. Now the new version codes are dumped into the processor but i didnt got ouput.
    And also i try the same  c code in older keil version which one is used. But there is no output.
