DS52020.0 connection to Musca-A/B boards not working
Hi guys,
Going straight to the point, we recently had access to a license for Arm DS52020.0 and while trying to start a debug connection to Musca-A1 or B1 boards we are getting a failed connection output.
I tried to install the tool on both a Linux and Windows systems.
1) On Linux, I created a new "Generic Arm C/C++ Application" debug configuration. I selected the target to connect and changed the type of connection to "CMSIS-DAP". For both platforms, I can't browse the connection. More specifically, when I open the "Browse" window the connection is there, but when I try to select it, the option just simply disappears.
2) On Windows, I followed the same steps, but I was able to select the target on the "Connection Browser" window. On the Debugger tab I selected the option "Debug from symbol" after given the application path to be downloaded to the target. As soon as I start the Debug session I get the following errors for each board:
Musca-A1
Musca-B1
Is there something that I'm doing wrong ?
Thank you.
