ARM64 Linaro toochain Link error ( R_AARCH64_ADR_PREL_PG_HI21 )
Hi Experts,
We are using address which is more than 32 bits with for example : 0x1000000000
when comes to adrp instruction it is giving following error.:
relocation truncated to fit: R_AARCH64_ADR_PREL_PG_HI21 against symbol `__BSS_START__' defined in .bss section in
ADRP Usage:
adrp    x0, __BSS_START__
add    x0, x0, :lo12:__BSS_START__
what could be possible solution for this?
When I tried to replace adrp and add with ldr instruction it works fine but is there any way that we can continue with adrp instruction?
LDR Usage:
ldr x0, = __BSS_START__
We are using aarch64-linux-gnu-gcc (Linaro GCC 6.2-2016.11) 6.2.1 20161016 toolchain.
