I started using Development Studio. I created a Hello World, and compiled it. Than I created a launch configuration, just very simple per this tutorial:https://developer.arm.com/tools-and-software/embedded/legacy-tools/ds-5-development-studio/resources/tutorials/debugging-hello-world-in-c-on-a-fixed-virtual-platform-fvp
However, I get a warnings "Simulation code-translation cache failed to gain DMI":
terminal_0: Listening for serial connection on port 5000terminal_1: Listening for serial connection on port 5001terminal_2: Listening for serial connection on port 5002terminal_3: Listening for serial connection on port 5003CADI server started listening to port 7000 Info: FVP_VE_Cortex_A9x1: CADI Debug Server started for ARM Models... cadi server is reported on port 7000ARM Core Model: WARNING - Simulation code-translation cache failed to gain DMI for PC=0x0000801c. Simulation performance will be reduced.ARM Core Model: WARNING - Simulation code-translation cache failed to gain DMI for PC=0x0000801c (PA = s_-0000801c. Simulation performance will be reduced.
After this everything just stands still at first line of main(), and whatever I try - nothing happens. I can't F8 Continue, nor Step, etc.
All windows are also empty, like Disassembly, etc.
What could be wrong?
I also first tried to do my own more complicated app, but I got completely the same behavior. That's why I went back to simple HelloWorld, but it didn't help.
The Command windows shows this:
Connected to stopped target Arm FVP (Installed with Arm DS) - VE_Cortex_A9x1cd "C:\Users\D\Development Studio Workspace"Working directory "C:\Users\D\Development Studio Workspace"loadfile "C:\Users\D\Development Studio Workspace\t3\Debug\t3.axf"Execution stopped in SVC mode at S:0x00000000S:0x00000000 DCI 0xe7ff0010 ; ? UndefinedLoaded section ER_RO: S:0x00008000 ~ S:0x000092E7 (size 0x12E8)Loaded section ER_RW: S:0x000092E8 ~ S:0x000092F7 (size 0x10)Entry point S:0x00008000Semihosting server socket created at port 8000Semihosting enabled automatically due to semihosting symbol detected in image 't3.axf'set debug-from mainstartStarting target with image C:\Users\Danijel\Development Studio Workspace\t3\Debug\t3.axfRunning from entry pointwait
set debug-from main
start
wait
