Hello
I just installed IDE and trying to port existing code compiled at Linux ARMCC into IDE environment. I followed the guideline in the armds_user_guide 2.4 Create a new Makefile project with existing code, and the below is error I have seen now..
12:39:09 **** Build of configuration Default for project Sort_App ****make all del *.o *.txt *.log *.img *.disCould Not Find C:\ARM\DSWorkSpace\sort_app\sort_v8_mpcore.1uart\*.odel *.axf *.binCould Not Find C:\ARM\DSWorkSpace\sort_app\sort_v8_mpcore.1uart\*.axfarmclang -c -g -O0 sorts.c -o sorts.o -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult -std=c90process_begin: CreateProcess(NULL, armclang -c -g -O0 sorts.c -o sorts.o -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult -std=c90, ...) failed.make (e=2): The system cannot find the file specified.
make: *** [Makefile:80: sorts.o] Error 2"make all" terminated with exit code 2. Build might be incomplete.
12:39:09 Build Failed. 1 errors, 0 warnings. (took 180ms)
The Makefile script looks as below. It was compiled well in Linux environment, and sample code provided by ARM:
#############################################################################CC=armclangAS=armasmLD=armlink#AS=/engr/dev/tools/arm/DS-5/sw/ARMCompiler6.01u1/bin/armasm#LD=/engr/dev/tools/arm/DS-5/sw/ARMCompiler6.01u1/bin/armlinkAR=armarFE=fromelf
ifeq ($(OSTYPE),linux)DEL = rm -rfelseDEL = delendif
################################################################################# Targets##
all: cleanall sorts_v8.axf sorts_v8.dis trim
############################################################################## Auxillary Maintainence Targets.
clean: $(DEL) *.o *.txt *.log *.img *.dis
cleanall: clean $(DEL) *.axf *.bin
trim: $(DEL) *.o
############################################################################## Object files from C and ASM code
uart.o: uart.c# Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 -Os $^ -o $@ -target aarch64-arm-none-eabi --tool_variant=ult
retarget.o: retarget.c# Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 -Os $^ -o $@ -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult
serial.o: serial.c# Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 -Os $^ -o $@ -target aarch64-arm-none-eabi --tool_variant=ult
sorts.o: sorts.c# Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 $^ -o $@ -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult -std=c90
Would you like to help me where can I get the guidance about this...?
Thank you so much!!
Hello. Let me upload the code and ask again in a more detail. I am a real beginner of IDE(using temporal license ) and struggling a lot..
The below CODE2 is makefile which was used, and when I import existing C-code into IDE and compile it, I see the below error:
ERROR:
21:04:08 **** Build of configuration Default for project Sort **** make all del *.o *.txt *.log *.img *.dis del *.axf *.bin armclang -c -g -O0 sorts.c -o sorts.o -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult -std=c90 process_begin: CreateProcess(NULL, armclang -c -g -O0 sorts.c -o sorts.o -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult -std=c90, ...) failed. make (e=2): The system cannot find the file specified. make: *** [Makefile:80: sorts.o] Error 2 "make all" terminated with exit code 2. Build might be incomplete. 21:04:08 Build Failed. 1 errors, 0 warnings. (took 188ms)
And then I found out that the IDE is not even find the armclang command.. In this case, how can I import existing C-code and makefile into ARM Development Studio..?
CODE2:
############################################################################# CC=armclang AS=armasm LD=armlink #AS=/engr/dev/tools/arm/DS-5/sw/ARMCompiler6.01u1/bin/armasm #LD=/engr/dev/tools/arm/DS-5/sw/ARMCompiler6.01u1/bin/armlink AR=armar FE=fromelf ifeq ($(OSTYPE),linux) DEL = rm -rf else DEL = del endif ############################################################################# ## ## Targets ## all: cleanall sorts_v8.axf sorts_v8.dis trim ############################################################################# # Auxillary Maintainence Targets. clean: $(DEL) *.o *.txt *.log *.img *.dis cleanall: clean $(DEL) *.axf *.bin trim: $(DEL) *.o ############################################################################# # Object files from C and ASM code uart.o: uart.c # Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 -Os $^ -o $@ -target aarch64-arm-none-eabi --tool_variant=ult retarget.o: retarget.c # Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 -Os $^ -o $@ -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult serial.o: serial.c # Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 -Os $^ -o $@ -target aarch64-arm-none-eabi --tool_variant=ult sorts.o: sorts.c # Compile for best debug view (lowest optimization) $(CC) $(CFLAGS) -c -g -O0 $^ -o $@ -target aarch64-arm-none-eabi -DSTANDALONE --tool_variant=ult -std=c90 startup.o: startup.s $(AS) -g --cpu=8-A.64.no_neon startup.s --dwarf3 --tool_variant=ult MP_Mutexes.o: MP_Mutexes.s $(AS) -g --cpu=8-A.64.no_neon MP_Mutexes.s --dwarf3 --tool_variant=ult ttb.o: ttb.s $(AS) -g --cpu=8-A.64.no_neon ttb.s --dwarf3 --tool_variant=ult stackheap.o: stackheap.s $(AS) -g --cpu=8-A.64.no_neon stackheap.s --dwarf3 --tool_variant=ult cpuUtils.o: cpuUtils.s $(AS) -g --cpu=8-A.64.no_neon cpuUtils.s --dwarf3 --tool_variant=ult ############################################################################# # Targets sorts_v8.axf: sorts.o retarget.o uart.o serial.o startup.o scatter.scat stackheap.o cpuUtils.o ttb.o MP_Mutexes.o $(LD) --scatter=scatter.scat sorts.o retarget.o uart.o serial.o startup.o stackheap.o cpuUtils.o ttb.o MP_Mutexes.o -o sorts_v8.axf --cpu=8-A.64.no_neon --entry=StartHere --force-scanlib --diag_suppress=6412,6329 --tool_variant=ult ############################################################################# # Disassembly files sorts_v8.dis: sorts_v8.axf fromelf -cads --interleave=source sorts_v8.axf > sorts_v8.dis #############################################################################
Hi mongolee,It looks like you are using a very old version of the “sorts” example (based on Arm Compiler 6.01!). The latest is Arm Compiler 6.14.Arm Development Studio includes many examples for the latest Arm Compiler 6, including more recent versions of the “sorts” example, for a wide range of Arm processors.Many of the examples include scatter files, and there are also some GCC equivalent versions of AC6 projects, that show the use of linker scripts.If you don’t already have the latest version 2020.0 of Arm Development Studio, then please feel free to download a free Evaluation version from developer.arm.com/.../evaluateTo access these and import them into your workspace, select File > Import > Arm Development Studio > Examples and Programming Libraries, then enter “startup” in the search filter.As a starting point, import the two ready-made, fully-working examples for Armv8-A: “startup_Armv8-A_AArch64_AC6” and its GCC version called “startup_Armv8-A_AArch64_AC6".You can then compare and contrast the these two examples. These are both “makefile”-based examples, that run of Fixed Virtual Platform (FVP) models included in Arm DS.Hope this helpsStephen
Thank you so much. I would really appreciate your kind answer!!
