Setup & Debug Android Native code with DS-5 pro v5.11
Note: This was originally posted on 19th December 2012 at http://forums.arm.com
Hi, while setup  & debug Android native code with DS-5 pro v5.11, some issues occurred:
Step1. Setting up the Android tools for use with DS-5
Due to the chapter "Setting up the Android tools for use with DS-5" in   ARM DS-5 tutorials , we setup Android software tools:
Android SDK: adt-bundle-windows-x86 and required SDK platforms
Android NDK: android-ndk-r8c-windows
Cygwin:   1.7.11
DS-5 Pro: v5.11
There are 2 vague configuration in setting up Procedure:
Issue1:  Which PATH environment variable should be updated?  MS Windows or Cygwin .bashrc or others?
Issue2: Are there any  requirements  about compatible revision between  DS-5, Android SDK, Andoid NDK?
Step 2: Loading the hello-neon application on to an Android target
Due to the chapter " Loading the hello-neon application on to an Android target" in   ARM DS-5 tutorials .
We imported HelloNeon project into Java workplace and generated libhelloneon.so,
but HelloNeon.apk could NOT be generate  with operation "Build Project".
However, HelloNeon.apk could be generate  with operation "Run As Android Application". and it works well on Emulator 5554:android 2.2.
Issue3: Are there any special settings to generate APK while "Build Project"?
When setting " Debug Configurations",  Error message was shown:
"Configuration for connection type 'gdbserver' is not valid - An Android device must be selected. If none are available then start one using AVD."
Since NO APK has been generated, Another Error message was showned (Snap8.jpg):
Issue 4: How to set "Debug Configurations"  and lauch Debug operation correctly?
Have Any talents Setup & Debug Android Native code with DS-5 pro v5.11 sucessfully?
Any comments/suggestions to resolve the above issues?
Thanks very much!
  • Note: This was originally posted on 28th December 2012 at http://forums.arm.com
    Are you still having these problems?  The most recent version of DS-5 is v5.13 -- I don't know if it addresses the problems you're having, but it is probably a better place to start from.
    The DS-5 instructions are referring to the Windows PATH.  DS-5 doesn't install or rely on Cygwin.  If you've installed it and it is influencing Eclipse then it may be necessarily to ensure things about it's path, too.
    What messages/errors are you getting?
    However, HelloNeon.apk could be generate  with operation "Run As Android Application". and it works well on Emulator 5554:android 2.2.Issue3
    Are you trying to use a real Android target or a virtual one?
