In ARM DS-> PCE->Devices, I am trying to auto-detect the component connections. Here my target is an emulator, using Cadence VDEBUG interface. My target have Coresight module which I am trying to connect to in DS.
I get the following error, when I try "Auto detect Component Connections". I was previously able to connect. I am not sure ablout what the following error code implies. Can you please help me find details about the error?
Starting debug serverWaiting for debug server to start accepting connectionsERROR : Another instance of the server is running
[08/04/20 18:40:30] Failed to launch debug server. Command: rddidap_serverdexited with error code: 1[08/04/20 18:40:30] Autodetection Failed
Hi SrigunGlad to hear you solved the problem.If you need more help with debugging on an emulator, I suggest you create an official support case with Arm, using Support -> "Open a case" from the above menu.Stephen
I kiiled this old deamon process "ds/sw/../sw/debughw/debug_server/rddidap_serverd -rddi_dap_dll" and then it worked.
