ARM Compiler 6: Armclang
  1. ARM Compiler 6 uses armclang, but armclang can't use the intrinsic functions(like __qadd) that has used in the previous compiler.How can I get the optimization code? (Does the intrinsic functions are better than the our codes,what are the codes in the function "_qadd"?
  2. Does the __saturate int the "dspfns.h" is error? it does not need to do double?
