I'm using DSTREAM with ARM DS-5 to program and Debug my FPGA with Cortex-R52. How Can I Reset my Target from the ARM DS-5 itself?
I've found a command "RESET" but where should I give the command? I'm new into this..
Hello, you can use the "reset" command in the command pane in the debugger, else you can use this button (pulldown) in the debug control pane:Note you must also ensure that the DSTREAM is correctly connected to the reset signals of the target, see:https://developer.arm.com/docs/dui0499/latest/arm-dstream-system-design-guidelines/reset-signals/dstream-reset-signals
