Hi:
I hope to get some help.If somebody has met the same problem as me?
Although gatord has already started on target board, streamline on host PC could not connect to gatord.The gatord version is updated.Target board also could 'ping' to host PC.
On pandaboard:
root@arm:/gator# ps ax | grep gatord
864 ttyO2 S< 0:00 ./gatord
987 ttyO2 S+ 0:00 grep --color=auto gatord
root@arm:/gator# netstat -pln
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 953/sshd
tcp6 0 0 :::22 :::* LISTEN 953/sshd
tcp6 0 0 :::8080 :::* LISTEN 864/gatord
tcp6 0 0 :::80 :::* LISTEN 749/apache2
tcp6 0 0 :::8082 :::* LISTEN 864/gatord
udp 0 0 0.0.0.0:43342 0.0.0.0:* 489/avahi-daemon: r
udp 0 0 0.0.0.0:11195 0.0.0.0:* 881/dhclient
udp 0 0 0.0.0.0:68 0.0.0.0:* 881/dhclient
udp 0 0 0.0.0.0:5353 0.0.0.0:* 489/avahi-daemon: r
udp6 0 0 :::30001 :::* 864/gatord
udp6 0 0 :::40418 :::* 489/avahi-daemon: r
udp6 0 0 :::29287 :::* 881/dhclient
udp6 0 0 :::5353 :::* 489/avahi-daemon: r
Active UNIX domain sockets (only servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ACC ] STREAM LISTENING 12806 426/dbus-daemon /var/run/dbus/system_bus_socket
unix 2 [ ACC ] SEQPACKET LISTENING 12358 206/systemd-udevd /run/udev/control
unix 2 [ ACC ] STREAM LISTENING 14410 489/avahi-daemon: r /var/run/avahi-daemon/socket
unix 2 [ ACC ] STREAM LISTENING 11892 1/init @/com/ubuntu/upstart
unix 2 [ ACC ] STREAM LISTENING 12947 597/acpid /var/run/acpid.socket
root@arm:/gator#
Why gatord did not listen to tcp but tcp6? Is there any problem?
