ARM DS-5 streamline unable to connect to gatord
Hi:
I hope to get some help.If somebody has met the same problem as me?
Although gatord has already started on target board, streamline on host PC could not connect to gatord.The gatord version is updated.Target board also could 'ping' to host PC.
On pandaboard:
root@arm:/gator# ps ax | grep gatord
  864 ttyO2    S<     0:00 ./gatord
  987 ttyO2    S+     0:00 grep --color=auto gatord
root@arm:/gator# netstat -pln
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      953/sshd
tcp6       0      0 :::22                   :::*                    LISTEN      953/sshd
tcp6       0      0 :::8080                 :::*                    LISTEN      864/gatord
tcp6       0      0 :::80                   :::*                    LISTEN      749/apache2
tcp6       0      0 :::8082                 :::*                    LISTEN      864/gatord
udp        0      0 0.0.0.0:43342           0.0.0.0:*                           489/avahi-daemon: r
udp        0      0 0.0.0.0:11195           0.0.0.0:*                           881/dhclient
udp        0      0 0.0.0.0:68              0.0.0.0:*                           881/dhclient
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           489/avahi-daemon: r
udp6       0      0 :::30001                :::*                                864/gatord
udp6       0      0 :::40418                :::*                                489/avahi-daemon: r
udp6       0      0 :::29287                :::*                                881/dhclient
udp6       0      0 :::5353                 :::*                                489/avahi-daemon: r
Active UNIX domain sockets (only servers)
Proto RefCnt Flags       Type       State         I-Node   PID/Program name    Path
unix  2      [ ACC ]     STREAM     LISTENING     12806    426/dbus-daemon     /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     SEQPACKET  LISTENING     12358    206/systemd-udevd   /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     14410    489/avahi-daemon: r /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     11892    1/init              @/com/ubuntu/upstart
unix  2      [ ACC ]     STREAM     LISTENING     12947    597/acpid           /var/run/acpid.socket
root@arm:/gator#
Why gatord did not listen to tcp but tcp6? Is there any problem?
