I'm using Arm Development Studio 2019.1 on Windows 10.
From within ARM Development Studio I select "Build Project" for my project. It starts executing but I get a Windows pop-up error for armcc.exe that says:
Application was unable to start correctly. (0xc0000142)
The make is invoking Arm C Compiler 5.
I have tried running Arm Development Studio both as a user and as an administrator but I get the same error in either case.
This error occurs on the first file to be compiled for the project.
I've done some searching and found that this error is raised when a DLL is not able to be initialized.
Has anyone else seen this error?
Ronan & Stephen,
Thank you for your suggestions and "debugging" tips! Once I removed all references to the AVR toolset I am no longer getting the windows error when I attempt to build the project. Turns out I had set the PATH values in both the user and all users area of windows environment variable settings.
I will have to come up with batch files to use so that when I switch projects and toolsets I get the correct environment variables for the appropriate toolset.
Again thank you for your help and patience.
Doug
