Can DS5 compile Linux kernel module?
Note: This was originally posted on 4th December 2012 at http://forums.arm.com
I have a newbie question re using ARM DS5.
Is DS5 compiler capable of compiling Linux kernel module? or it's limited to user space applications only?
Thanks,
AAli
  • Note: This was originally posted on 19th December 2012 at http://forums.arm.com
    Thanks for your kindly reply!
    quote name='scott' timestamp='1355829081' post='40270']
    [It would be better to start a thread since your question is about a different topic.  But I'll answer it here anyway.]
    Unfortunately, building general native Android code with armcc is not supported* so there aren't any instructions in the documentation, but if you have a standalone object file built with armcc you can link it with other native code. gcc can also compile NEON intrincics.
    • One reason is that the Android C library, Bionic, does not supply all of the functions that the AEABI requires.
      [/quote]
      [/quote]
