How can I get or build a FLM file for MPS3 for Cortex-m33
AFAIK the RO region in MPS3 from where an application binary would execute is RAM. I.e. a flash algorithm should not be needed. How can I transfer a binary to the target without a flash algorithm.
Or if an *.flm file is indeed needed, "flashing" to RAM should be a matter of copying data and should be generic. Does such a generic flm-file exist?
  • Hello Mambrus,
    which environment are you using. In MDK, you would use the LOAD command to send the image to the target without a FLM file:
    LOAD %L INCREMENTAL
    Kind regards,
    Christopher
  • To expand on the answer from Christopher, usually one disables the "load application at startup" or "download to target", and instead select an initialization file
    FUNC void Setup (void) { // Change 0x10000000 to 0x08000000 or 0x20000000 as appropriate
      SP = _RDWORD(0x10000000);             // Setup Stack Pointer
      PC = _RDWORD(0x10000004);             // Setup Program Counter
      _WDWORD(0xE000ED08, 0x10000000);      // Setup Vector Table Offset Register
    LOAD %L INCREMENTAL                     // Download
    Setup();                                // Setup for Running
    g, main
