AFAIK the RO region in MPS3 from where an application binary would execute is RAM. I.e. a flash algorithm should not be needed. How can I transfer a binary to the target without a flash algorithm.
Or if an *.flm file is indeed needed, "flashing" to RAM should be a matter of copying data and should be generic. Does such a generic flm-file exist?
To expand on the answer from Christopher, usually one disables the "load application at startup" or "download to target", and instead select an initialization file
FUNC void Setup (void) { // Change 0x10000000 to 0x08000000 or 0x20000000 as appropriate SP = _RDWORD(0x10000000); // Setup Stack Pointer PC = _RDWORD(0x10000004); // Setup Program Counter _WDWORD(0xE000ED08, 0x10000000); // Setup Vector Table Offset Register } LOAD %L INCREMENTAL // Download Setup(); // Setup for Running g, main
