J-Link fails to connect to target GR-Peach
I'm trying to build and load a linux kernel onto a R7S721001 processor and I'm using the GR-Peach as my evaluation board. However, connecting the JTAG interface to the J-Link produces a "TDO is constant high." error.
I thought I'd found the issue when I discovered that the nRZRST pin (pin 10) was not connected. The schematic I found for the board shows a R29 resistor but marks it as "not mount", so I looked for the empty spot, checked for a resistance with pin 10, and then shorted the connection with some solder. However, the J-Link still produces the "TDO is constant high" error.
Here's the Output from the JLinkExe Commander:
SEGGER J-Link Commander V6.54a (Compiled Oct 31 2019 17:38:48)
DLL version V6.54a, compiled Oct 31 2019 17:38:34
Connecting to J-Link via USB...O.K.
Firmware: J-Link EDU Mini V1 compiled Oct 22 2019 16:28:45
Hardware version: V1.00
S/N: 801012842
License(s): FlashBP, GDB
VTref=3.282V
Type "connect" to establish a target connection, '?' for help
J-Link>connect
Please specify device / core. <Default>: R7S721001
Type '?' for selection dialog
Device>
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF>
Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
JTAGConf>
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "R7S721001" selected.
Connecting to target via JTAG
Could not measure total IR len. TDO is constant high.
Cannot connect to target.
