For DS-5, How to select the toolchain, whether select_toolchain.bat support input parameter?
Hi All,
For DS-5, I want to select the toolchain by script automatically. whether select_toolchain.bat support  to take parameter directly?
like select_toolchain.bat 1
Thanks!
  • Hi fnjcr
    Sorry, select_toolchain.bat was not designed to accept a parameter directly, but it is possible to create a script based on it that performs what you want to do.
    Create a .bat file containing:
    @echo off
    for /f "delims=" %%a in ('..\sw\tcm\get_toolchain_path.bat "%~1"') do set TC_PATH=%%a
    set PATH=%TC_PATH%;%PATH%
    Then you can invoke this bat file from the DS-5 Command Prompt with a parameter, e.g.
    set_toolchain.bat "Arm Compiler 6 (DS-5 built-in)"
    Hope this helps
  • Hi fnjcr
    @echo off
    Hope this helps
