I am trying to create configdb entry for debug to conect to coresight using D-STREAM. I put ARMCS-DP in scan chain and try to configure .
Debug hardware config tool complains Coresight ROM table has failed - failed to read confi item DAP_CONFIG_INFO.
To debug furhter I used CSAT command line tool. I am able to read version ID and power up the DAP..
Here are the commands.
1) Con usb (connect to DStream)
2) chain dev=ARMCS-DP clk=20000 (put coresight in JTAG chain)
3) dvo 0 (This should print the ID)
4) drw DPACC.CSW 0x5400000 (Power up DAP)
5) drr DPACC.CSW (Please let know what you read back.)
I am using ARMv8. I want to use dmr command to read some memory location but CSAT doesn't take more than 32 bit addresses.
Any ideas how to overcome this hurdle.
Thanks in advance.
Shaibal
Hi Shaibal,
If you contact ARM technical support, they will be able to help you with the detail of creating a new configdb entry with your ARMv8 target.
Thanks,
Joe
