Hi everyone!
I am using arm ds-5 professional under evaluation license, and I am trying to collect call-graph info from my test application under arm via streamline, but faced with issue.
Collected call graph is flat, there is no hierarchy
But it should be something like this: main -> f1 -> f2
I have used all necessary options that mentions in manual: -fno-omit-frame-pointer -fno-inline and checked "Call stack unwinding"
I ran this code on remote arm machine under Ubuntu 14.04 build according to this manual https://git.linaro.org/arm/ds5/gator.git/blob/HEAD:/README_Streamline.txt
I' ve used this config options for stream line:
Could some one please explain me what i am doing wrong?
I have attached src and build.sh.
Thanks in advance
Hi dinar,
A flat or incomplete call path can occur for several reasons (several which you have already verified, but I will repeat for completeness):
The most likely cause is that the image is compiled for Thumb mode. To ensure the image is not compiled for Thumb mode, add the -marm option, as the compiler may be configured with --with-mode=thumb, thus making Thumb mode default.
