Streamline is not able to collect counters on Mali-G72 MP3 device. I have attached the screenshot of counters I am able to see. Is this a limitation of this GPU?
I suspect gatord can't access sysfs to find out which GPU you have in the device. Run the gator daemon with the "-M G72" command line option added
How do we run using command line? I run the gatord daemon apk on the android device directly.
Don't use the APK, it doesn't work with the new Android security model (it's actually been removed in the latest versions of Mobile Studio). There is a command line daemon in the installation, but if you have the APK you are probably using some of the older tools, so first I would recommend updating to Mobile Studio 2019.1.
The latest version of Mobile Studio can be downloaded from here:
* https://developer.arm.com/tools-and-software/graphics-and-gaming/arm-mobile-studio/downloads
The user guide for using the command line daemon can be found here:
* https://developer.arm.com/tools-and-software/graphics-and-gaming/arm-mobile-studio/learn/get-started/get-started-with-streamline
HTH, Pete
Thanks Pete. I am able to collect the data now.
Great, glad we got it working for you. Let us know if you have any more questions.
Kind regards, Pete
