If I Wanted to Search for "android-ndk7b + DS-5 + gdbserver" Here ...
Note: This was originally posted on 21st February 2012 at http://forums.arm.com
If I Wanted to search for "android-ndk7b + DS-5 + gdbserver" here, how would I?
Reason is, I can't debug with ds-5 as described.  It doesn't work.  Can't connect to port 5000.  Using the ndk7b gdbserver, it seems to  work.  Is it supposed to?
Directory of c:\android\android-ndk-r7b\samples\native-media\libs\armeab
2011.11.29  13:36           187,992 gdbserver__ds5   ... does not work in 7b
2012.01.25  08:39           125,208 gdbserver
2012.01.25  08:39           125,208 gdbserver_org
If I wanted to know if this was a known problem, how would I find out?
  • Note: This was originally posted on 23rd February 2012 at http://forums.arm.com
    Yes, the dyna one works okay.  Maybe you can shed some light on this, ever-present problem with apps, and ds-5 CE is no exception unfortunately.  Color clash.  Some views don't offer any way to change the colors, and hard code clashing values.  Look at the register view in the screenshot (imageshack.us)
    [IMG]http://img259.imageshack.us/img259/3292/ds5colorclash.png[/IMG]
    Also, the highlight bar color does not stick on a restart (always goes back to that green from the dark gray I set for it).  I have no idea from where the white color comes since this Win7 box is set to use high-contrast mode (the main reason is to get black backgrounds in apps since most stick with white and don't offer a way to change).  I don't think there's a way to fix that once an app has fallen into the hole.  It's a terribly common problem.
