Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Software Tools
Jump...
Cancel
Software Tools
Arm Development Studio forum
DS-5 Problem starting gdbserver to debug android NDK application
Tools, Software and IDEs blog
Forums
Videos & Files
Help
Jump...
Cancel
New
Replies
Subscribers
126 subscribers
Views
Users
0 members are here
Related
Offline
Nivelinn Pantev
over 7 years ago
Note: This was originally posted on 29th December 2011 at http://forums.arm.com
Hi Everyone,
I am facing problem when starting debug session for native code debugging using DS-5 CE,
This is what is shown:
eclipse.buildId=M20110909-1335
java.version=1.6.0_26
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.cpp.product
Error
Wed Dec 28 20:51:17 EET 2011
Failed gdbserver configuration:
Timeout. PID not found!
com.arm.debugger.control.target.TargetControllerException: Failed gdbserver configuration:
at com.arm.debugger.control.target.TargetController.runGDB(TargetController.java:623)
at com.arm.debugger.control.target.TargetController.setupAndroid(TargetController.java:108)
at com.arm.debugger.control.target.TargetController.setupGdbServerOnTarget(TargetController.java:121)
at com.arm.debugger.control.target.TargetController.setupTarget(TargetController.java:78)
at com.arm.debugger.control.ConnectionController.doPreDebugServiceInitialization(ConnectionController.java:592)
at com.arm.debugger.control.ConnectionController.doInitialize(ConnectionController.java:533)
at com.arm.debugger.control.ConnectionController.manageThreadModelAndInitialize(ConnectionController.java:524)
at com.arm.debugger.control.ConnectionController.manageConnectionCleanupAndInitialize(ConnectionController.java:510)
at com.arm.debugger.control.ConnectionController.manageProgressResourceAndInitialize(ConnectionController.java:463)
at com.arm.debugger.control.ConnectionController.initializeNonModelConnection(ConnectionController.java:435)
at com.arm.debugger.control.ConnectionController.initialize(ConnectionController.java:410)
at com.arm.debugger.control.ConnectionManager.createConnection(ConnectionManager.java:391)
at com.arm.debugger.launcher.TargetLauncher.connect(TargetLauncher.java:70)
at com.arm.debugger.launcher.TargetLauncher.launch(TargetLauncher.java:44)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:928)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1132)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
The set-up the environment is based on these guidelines:
http://infocenter.ar...h/CIHEEGJH.html
http://kernel.ozandroid.info/?p=83
I am on 32 bit Ubuntu 11.10 host and debugging is on avd API level 14
What could be the problem?
Thanks a lot in advance!
Offline
Albert Cano Camps
over 7 years ago
Cancel
Up
0
Down
Cancel
Offline
Nivelinn Pantev
over 7 years ago
Note: This was originally posted on 4th January 2012 at
Hi Albert,
And thanks a lot for your assistance!!!
I am going to perform the suggested tests ASAP and let you know what the results are!
Thanks again,
Best Regards,
N
Cancel
Up
0
Down
Cancel
Offline
Nivelinn Pantev
over 7 years ago
Note: This was originally posted on 7th January 2012 at
Hi Guys,
I tried once more with hello neon example from NDK.
No problem to install and run the application via adb
app_40 2673 1103 119440 30764 ffffffff 400b03c4 S com.example.neon
No problem as well to install and debug Java part via ADT plug-in.
But this is what logcat is showing when trying DS-5:
01-05 17:29:39.184: D/AndroidRuntime(6871): Shutting down VM
01-05 17:29:39.196: D/dalvikvm(6871): GC_CONCURRENT freed 101K, 77% free 483K/2048K, paused 1ms+1ms
01-05 17:29:39.196: D/jdwp(6871): Got wake-up signal, bailing out of select
01-05 17:29:39.196: D/dalvikvm(6871): Debugger has detached; object registry had 1 entries
01-05 17:29:39.226: I/jdwp(89): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.226: I/AndroidRuntime(6871): NOTE: attach of thread 'Binder Thread #3' failed
01-05 17:29:39.237: I/jdwp(143): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.268: I/jdwp(157): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.277: I/jdwp(167): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.309: I/jdwp(184): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.326: I/jdwp(213): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.336: I/jdwp(229): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.364: I/jdwp(258): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.382: I/jdwp(291): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.417: I/jdwp(309): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.432: I/jdwp(326): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.459: I/jdwp(350): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.489: I/jdwp(369): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.489: I/WindowManager(89): createSurface Window{415cae40 Starting com.example.neon paused=false}: DRAW NOW PENDING
01-05 17:29:39.497: I/jdwp(394): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.516: I/jdwp(412): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.538: I/jdwp(800): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.558: I/jdwp(829): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.596: I/jdwp(872): Ignoring second debugger -- accepting and dropping
01-05 17:29:39.618: I/jdwp(941): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.076: D/dalvikvm(6882): Not late-enabling CheckJNI (already on)
01-05 17:29:40.149: I/ActivityManager(89): Start proc com.example.neon for activity com.example.neon/.HelloNeon: pid=6882 uid=10040 gids={1015}
01-05 17:29:40.198: I/jdwp(89): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.207: I/jdwp(143): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.234: I/jdwp(157): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.246: I/jdwp(167): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.258: I/jdwp(184): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.286: I/jdwp(213): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.308: I/jdwp(229): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.329: I/jdwp(258): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.339: I/jdwp(291): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.357: I/jdwp(309): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.377: I/jdwp(326): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.422: I/jdwp(350): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.438: I/jdwp(369): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.458: I/jdwp(394): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.468: I/jdwp(412): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.478: I/jdwp(800): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.496: I/jdwp(829): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.518: I/jdwp(872): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.539: I/jdwp(941): Ignoring second debugger -- accepting and dropping
01-05 17:29:40.828: W/NetworkManagementSocketTagger(89): setKernelCountSet(10040, 1) failed with errno -2
01-05 17:29:41.078: D/dalvikvm(6882): Trying to load lib /data/data/com.example.neon/lib/libhelloneon.so 0x413469f0
01-05 17:29:41.088: D/dalvikvm(6882): Added shared lib /data/data/com.example.neon/lib/libhelloneon.so 0x413469f0
01-05 17:29:41.088: D/dalvikvm(6882): No JNI_OnLoad found in /data/data/com.example.neon/lib/libhelloneon.so 0x413469f0, skipping init
01-05 17:29:41.198: I/helloneon(6882): enter app.....
01-05 17:29:44.216: V/PhoneStatusBar(143): setLightsOn(true)
It seems problem to run gdbserver.
I tried on a real Android device (Linaro Android on i.MX53 QSB), again application is installed and started, but gdbserver PID cannot be found:
logcat:
01-08 00:38:23.110: D/AndroidRuntime(1931): Calling main entry com.android.commands.am.Am
01-08 00:38:23.150: I/ActivityManager(1176): START {flg=0x10000000 cmp=com.example.neon/.HelloNeon} from pid 1931
01-08 00:38:23.210: D/dalvikvm(1941): Not late-enabling CheckJNI (already on)
01-08 00:38:23.220: D/AndroidRuntime(1931): Shutting down VM
01-08 00:38:23.220: I/ActivityManager(1176): Start proc com.example.neon for activity com.example.neon/.HelloNeon: pid=1941 uid=10040 gids={1015}
01-08 00:38:23.240: D/dalvikvm(1931): GC_CONCURRENT freed 101K, 77% free 483K/2048K, paused 0ms+1ms
01-08 00:38:23.240: I/AndroidRuntime(1931): NOTE: attach of thread 'Binder Thread #3' failed
01-08 00:38:23.240: D/jdwp(1931): Got wake-up signal, bailing out of select
01-08 00:38:23.240: D/dalvikvm(1931): Debugger has detached; object registry had 1 entries
01-08 00:38:23.430: D/dalvikvm(1176): GC_EXPLICIT freed 340K, 19% free 10201K/12487K, paused 4ms+8ms
01-08 00:38:23.580: D/dalvikvm(1941): Trying to load lib /data/data/com.example.neon/lib/libhelloneon.so 0x41052a48
01-08 00:38:23.580: D/dalvikvm(1941): Added shared lib /data/data/com.example.neon/lib/libhelloneon.so 0x41052a48
01-08 00:38:23.590: D/dalvikvm(1941): No JNI_OnLoad found in /data/data/com.example.neon/lib/libhelloneon.so 0x41052a48, skipping init
01-08 00:38:23.610: I/helloneon(1941): enter app.....
01-08 00:38:24.030: W/ActivityManager(1176): Activity pause timeout for ActivityRecord{411f2e40 com.example.neon/.HelloNeon}
01-08 00:38:25.990: I/WindowManager(1176): createSurface Window{411f15e0 com.example.neon/com.example.neon.HelloNeon paused=false}: DRAW NOW PENDING
Cancel
Up
0
Down
Cancel
Offline
Albert Cano Camps
over 7 years ago
Cancel
Up
0
Down
Cancel
Offline
Nivelinn Pantev
over 7 years ago
Note: This was originally posted on 9th January 2012 at
Well, negative as well.
the application is running:
app_40 691 37 130940 34864 ffffffff 40011384 S com.example.neon
but:
Error
Mon Jan 09 19:38:01 EET 2012
at com.arm.debugger.launcher.TargetLauncher$ConnectJob.run(TargetLauncher.java:99)
Cancel
Up
0
Down
Cancel
Offline
Albert Cano Camps
over 7 years ago
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
DSTREAM Probe damage - Spare parts?
0
DSTREAM
11284
views
2
replies
Latest
6 months ago
by
SamGKN
Suggested Answer
Optimized ARM version of memcmp
0
9866
views
3
replies
Latest
6 months ago
by
Ronan Synnott
Not Answered
Develop Kotlin apps with OpenCl to run in a Samsung mobile that use Mali G71
0
8852
views
2
replies
Latest
6 months ago
by
ARMStrongssen
Answered
FVP Debug problems for Blinky Example project on Cortex-M4
0
Fixed Virtual Platforms (FVPs)
Debugging
Cortex-M4
9685
views
2
replies
Latest
6 months ago
by
Sagittarius
Answered
Product license check-out for feature "platform_editor:202003" failed
0
ARM Development Suite (ADS)
DSTREAM
9865
views
2
replies
Latest
6 months ago
by
David DV
