Hi Experts,
What is the way to identify the static stack frame size of the each routines in the C program ?
For example, in GCC ARM mode compiled c program the disassembly code is generated and in that there will be an instruction as follows
sub sp,sp, #10
where #10 is the stack frame size of the routine.
But in case of thum mode compilation or arm-thumb interworking, I am unable to find this instruction rather it is formed as
push/mov.w instructions.
Is there any tool or way to detect the static stack frame size of each routines ?
Here there is some information about the ARM Stack
You'll have to use a : "gcc -S" to get assembler output from your C programs directly
