Hello, I post here a question I have made already, but probably this is the right forum,
since I have not received answer till now.
I need some clues (better if it is a code example) about how to set up triggers in a way that a trace
disable in a core will automatically set the trace disable for all core in a cluster (without invalidating
the contents in ETB). So far, that's the sequence I have:
for(i=0; i<cpu_to_trace; i++) cs_trace_disable(devices.ptm[i]);if (itm) { cs_trace_disable(devices.itm);}cs_sink_disable(devices.etb);if (devices.itm_etb != NULL) { cs_sink_disable(devices.itm_etb);
(cs_xxx functions are taken from csaccess.c ARM file). This could take too long time
and I'd like to freeze the contents of PTM/ETB quite soon when requested
(and for all cores housed in a cluster).
Thanks in advance for your kind answers.
Best Regards,
Carlo
