Does anyone have experience with USB Mass Storage Device? I want to connect my arm device via usb cable to PC so my PC can read data from it?
Hi bojana.djukic,
The LPC2378 has been around for a while and there is a wealth of examples from many sources. Here at ARM we typically refer to the Keil Examples, specifically for the LPC23798 as a Mass storage device there is an example using the Keil tools. This is available at the following link...
LPC2368 / LPC2378 USB Mass Storage Device Example
I hope this helps!
Thanks,Ken
I solved my problem, one jumper was badly connected. But when I connect it my PC see only txt file, README, but I don't have idea where to change content and name of that file...
The README.txt file is derived from the DiskImg.c file in the project. To preload the USB with a different file this file would have to be modified accordingly. Several people have asked similar questions on the keil.com forum so you are not alone. I suggest reading the following forum post on the keil.com site...
USB and MSC class sample
