Debugging a Usage Fault for an unaligned memory access
I am experiencing a hard fault in Cortex M3 and bit#30 FORCED is set in the Hard Fault Status Register (0xE000ED2C). Referring to the Cortex M3 Technical Reference Manual:
[color="#0000FF"][30] FORCED Hard Fault activated because a Configurable Fault was received and cannot activate because of priority or because the Configurable Fault is disabled. The Hard Fault handler then has to read the other fault status registers to determine cause.[/color]
The value in the Configurable Fault Status Registers (0xE000ED28) is 0x01000000 which means that the bit#8 UNALIGNED is set in the Usage Fault Status Register (0xE000ED2A) . Again referring to the Cortex M3 Technical Reference Manual:
[color="#0000FF"][8] UNALIGNED When UNALIGN_TRP is enabled (see Configuration Control Register on page 8-25), and there is an attempt to make an unaligned memory access, then this fault occurs. Unaligned LDM/STM/LDRD/STRD instructions always fault irrespective of the setting of UNALIGN_TRP.[/color]
The value in the Configuration Control Register (0xE000ED14) is 0x00000200 which means that only bit#9 STKALIGN is set.
After reading through the relevant topics in this forum, I added the following code snippet to narrow down the problem.
[font="Courier New"]void hard_fault_handler_c(unsigned int * hardfault_args)
unsigned int stacked_r0;
unsigned int stacked_r1;
unsigned int stacked_r2;
unsigned int stacked_r3;
unsigned int stacked_r12;
unsigned int stacked_lr;
unsigned int stacked_pc;
unsigned int stacked_psr;
stacked_r0 = ((unsigned long) hardfault_args[0]);
stacked_r1 = ((unsigned long) hardfault_args[1]);
stacked_r2 = ((unsigned long) hardfault_args[2]);
stacked_r3 = ((unsigned long) hardfault_args[3]);
stacked_r12 = ((unsigned long) hardfault_args[4]);
stacked_lr = ((unsigned long) hardfault_args[5]);
stacked_pc = ((unsigned long) hardfault_args[6]);
stacked_psr = ((unsigned long) hardfault_args[7]);
printf ("[Hard fault handler]\n");
printf ("R0 = %x\n", stacked_r0);
printf ("R1 = %x\n", stacked_r1);
printf ("R2 = %x\n", stacked_r2);
printf ("R3 = %x\n", stacked_r3);
printf ("R12 = %x\n", stacked_r12);
printf ("LR = %x\n", stacked_lr);
printf ("PC = %x\n", stacked_pc);
printf ("PSR = %x\n", stacked_psr);
printf ("BFAR = %x\n", (*((volatile unsigned long *)(0xE000ED38))));
printf ("CFSR = %x\n", (*((volatile unsigned long *)(0xE000ED28))));
printf ("HFSR = %x\n", (*((volatile unsigned long *)(0xE000ED2C))));
printf ("DFSR = %x\n", (*((volatile unsigned long *)(0xE000ED30))));
printf ("AFSR = %x\n", (*((volatile unsigned long *)(0xE000ED3C))));
while(1);
__asm void Hard_Fault_Handler(void)
IMPORT hard_fault_handler_c
TST LR, #4
ITE EQ
MRSEQ R0, MSP
MRSNE R0, PSP
B hard_fault_handler_c
}[/font]
However, I am still not able to figure out and point out the instruction which is causing the issue .
Any help will be very much appreciated. I can provide more information if needed.
Thank you.
Regards,
  • Note: This was originally posted on 14th May 2010 at http://forums.arm.com
    Hi Brown,
    > My apology for the late response. I was out-of-office for 2 days and couldn't access the Internet.
    No problem. I will be busy most time next week myself so it is unlike for me to do much followup on this next week.
    Assumed that the watchdog reset is working properly, then the interrupt enable for in the NVIC should be all cleared.
    Depends on the microcontroller you use, the watchdog reset might also reset the peripherals.
    However, PendSV exception do not have an enable control as interrupts do.  PendSV is triggered by software only.
    So it is unrelated to peripheral not being reset.
    However, from your descriptions I am wonder if you are trying to reset by executing reset handler rather than doing a proper reset.
    Or are you talking about using watchdog to reset the system? it is not clear to me.
    I guess you need to talk to your OS provider to try to figure out what is the best way to solve this problem.
    regards,
    Joseph
    Hi Brown,
    regards,
    Joseph
