ARM64 Linaro toochain Link error ( R_AARCH64_LD_PREL_LO19 )
Hi Experts,
I am getting following linker error from Linaro aarch64 tool chain( aarch64-linux-gnu-gcc, gcc-linaro-aarch64-linux-gnu-4.8-2014.03_linux),  for our code which uses  pBitReverseIndex, pSignTable  global pointers which is declared out side the assembly file.
Linking CXX executable decoder-app
(.text+0x14): relocation truncated to fit: R_AARCH64_LD_PREL_LO19 against symbol `pBitReverseIndex' defined in .data.rel section in ../../../../*****.a(dct.c.o)
../../../..**********r.a(dct_opt.s.o): In function `dct':
(.text+0x20): relocation truncated to fit: R_AARCH64_LD_PREL_LO19 against symbol `pRevTable' defined in .data.rel section in ../../../../l*****r.a(dct.c.o)
../../../../lib-decoder/libhd-decoder.a(dct_opt.s.o): In function `dct':
(.text+0x28): relocation truncated to fit: R_AARCH64_LD_PREL_LO19 against symbol `pSignTable' defined in .data.rel section in ../../../..*******.a(dct.c.o)
../../../../****r.a(dct_opt.s.o): In function `L_PreRotateLoop':
collect2: error: ld returned 1 exit status
The DCT assembly function uses BitReverseIndex, SignTable, CosineTable etc. declared inside DCT.c
We are using LDR instruction inside assembly to load the address of these tables :
LDR                 x17, pSignTable
LDR                 x15, pRevTable
These tables and pointers are declared DCT.c
const Int32 SignTable[4]= {1, 1, 1, -1};
const Int8 RevTable[16]= {0,1,2,3,4,5,6,7,0xc,0xd,0xe,0xf,8,9,0xa,0xb};
const Int8* const pRevTable = RevTable;
const Int32* const pSignTable = SignTable;
We also tried with ADR instruction which satisfies position independent coding. But we couldn't fix this issue.
