Hello Friends,
I have bought Allied-vision GC2450 GigE camera and download its sample Code for Viewing its Imageries/Video. i need to just compile these sample code by typing command like
# make sample it generate a executable file and
# ./SampleViewer launch it's GUI which Display image or video capture from GC2450C
all the sample code provided by Allied-vision use their libraries like PvAPI.h
when i write a sample "hello world" code and cross compile using command
#arm-linux-gnueabi-gcc-4.4 test.cpp -o test
and load this file to SocKit and run it , it display Hello World Perfectively
then i just add the PvAPI.h file to same hello world file it generate various error like
/home/kaushal/Desktop/ArmCode/test/PvApi.h:103: error: #error Define PVDECL to be your compiler keyword for "standard call"/home/kaushal/Desktop/ArmCode/test/PvApi.h:368: error: #error Define specific data types for your platform./home/kaushal/Desktop/ArmCode/test/PvApi.h:259: error: expected ‘)’ before ‘*’ token/home/kaushal/Desktop/ArmCode/test/PvApi.h:353: error: expected ‘)’ before ‘*’ token/home/kaushal/Desktop/ArmCode/test/PvApi.h:443: error: expected initializer before ‘PvVersion’/home/kaushal/Desktop/ArmCode/test/PvApi.h:463: error: expected initializer before ‘PvInitialize’/home/kaushal/Desktop/ArmCode/test/PvApi.h:476: error: expected initializer before ‘PvUnInitialize’/home/kaushal/Desktop/ArmCode/test/PvApi.h:510: error: expected initializer before ‘PvLinkCallbackRegister’
whereas the same files works fine while i do "make sample"
now my question is how do i cross compile this code for ARM processor
i have Altera SoCKIT Board having ARM CORTEX-A9 Processor
Regards
kaushal
Hi Kaushal,
Just looking at the errors you're getting, it looks like you need to add:
#define PVDECL __stdcall
before you include the PvAVI.h header file.
I couldn't say for sure whether this will help, but Google tells me other people have run into the same problem and solved it that way.
Did you have any luck with this in the end?
It Start Working, its a Environmental variable issue...by setting the following environmental variable all the error gone.
export LIBRARY_PATH=/usr/lib/$(gcc -print-multiarch)
export CPLUS_INCLUDE_PATH=/usr/include/$(gcc -print-multiarch)
export C_INCLUDE_PATH=/usr/lib/$(gcc -print-multiarch)
*But each time i power on the machine i need to set these variables , how do i permanently set them.
