I'm trying DS5/streamline/ energy probe to measure CPU power with a simple power test ucode.
I want run the ucode and measure CPU power under bootloader. Because the bootloader is a simple environment.
After set capture options and connect energy probe, I press start capture button in streamline data, pop a dialog window: unknown host: xxx.
My DS-5 version is 5.15.0.
Must setup the gator.ko , gatord and adb if use energy probe?
Must energy probe measure under linux kernel or android?
Can use energy probe under bootloader?
Thanks for your attention!
Hi Yan
Yes, Energy Probe works in conjunction with a target running the gator daemon and generating a Streamline report. See Chapter 12 of http://infocenter.arm.com/help/topic/com.arm.doc.dui0482p/DUI0482P_using_arm_streamline.pdf
Ronan
