Now I want to use armcc to compile the c++ program and I want to find a example under DS-5 studio. I find under the DS-5 directory there is a CPP directory. There is a c++ example program for me to refer to. But after I study the makefile file, I have some question to ask for help. The first question is why the c++ program must include the "SYSROOT = ../distribution/filesystem/armv5t_mtx". The directory "lib and include" under the DS-5 directory can not meet the c++ program's need? The c++ program need the lib and headfile under the SYSROOT location? The second question is there is a command line paramter "--arm-linux-configure-file" and what is the paramter's function. I do not know it all. Please tell me the answer. Thanks!
If you are just trying to build a simple bare-metal application, then no special options are needed. Simply call your source file a .cpp file, and the compiler will build accordingly.
The options above are related to building a linux application with the ARM compiler. This is a deprecated feature - we would recommend using the provided gcc instead if you are doing this.
