I want to debug the Cortex-A15 MP from renesas (r8a7791) with the DStream, but the chip is not list in the debug configuration connection tab.
I have tried to select the other A15 to connect the target, but it didn't work.
So what can I do to make it?
Hiya
Have a look at ARM DS-5 ARM DS-5 Debugger User Guide : 2.9 About the target configuration import utility
You should use an utility called dbghwconfig to scan your device and follow the steps to import the resulting file into the tool.
If you are on a valid technical support contract, contact our Support team and they will help you.
Cheers!
Thanks. And I meets some problems. The auto configure of dbghwconfig configured the target partly.
Below is the Disassembly window snapshot, you can see that each instruction is 2 bytes instead of 4 bytes.
I have query the Memory window, the data is right. And all these address is in SoC intern RAM. The load/restore is OK, and I can stop the SoC.
And other:
From my ARM license manager, it hints:
Support and maintenance for ARM DS-5 expired on Mar 31, 2014. You are no longer able to install DS-5 updates or consult ARM Support experts. To restart support and maintenance visit http://ds.arm.com/s-and-m.
Can I get support from ARM still?
