Specifically with LPC2138, I want to convert the code written for 8051
Hello friends, I need your help
have time programming code for 8051 (c51) in keil and have no problem
but now I would like to start with arm, specifically with LPC2138 and I want to convert the code I show is written for 8051
but I can not do start All I know is how to define ports and little else.
I swear I've tried but have not succeeded.
the code is for a led matrix display and Works fine
please can help me?
the arm is no attempt to use the uart
thank you very much
the code in 8051 is:
  1.   //crystal is 22-24MHz
  2. //was made for Keil compiler
  3. #include
  4. #define BAUDRATE 9600
  5. sbit Cclock=P1^1;
  6. sbit Clatch=P1^0;
  7. sbit Cdata=P3^7;
  8. sbit Row1=P1^2;
  9. sbit Row2=P1^3;
  10. sbit Row3=P1^4;
  11. sbit Row4=P1^5;
  12. sbit Row5=P1^6;
  13. sbit Row6=P1^7;
  14. sbit Row7=P3^2;
  15. sbit Row8=P3^3;
  16. unsigned int shift_delay;
  17. unsigned char code font[96][16] =
  18. {
  19.    /* character 0x0020 (' '): (width=7, offset=0) */
  20. {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  21. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
  22. /* character 0x0021 ('!'): (width=8, offset=14) */
  23. {0XFF,0XE,0X78,0X78,0XE0,0XFF},
  24. /* character 0x0022 ('"'): (width=8, offset=30) */
  25. {0x00, 0xE0, 0xE0, 0x00, 0x00, 0xE0, 0xE0, 0x00,
  26. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
  27. /* character 0x0023 ('#'): (width=8, offset=46) */
  28. {0x00, 0x22, 0xFF, 0xFF, 0x22, 0xFF, 0xFF, 0x22,
  29. 0x00, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00},
  30. /* character 0x0024 ('$'): (width=8, offset=62) */
  31. 0x00, 0x61, 0xF1, 0x98, 0x8C, 0xC7, 0x43, 0x00,
  32. 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00,
  33. /* character 0x0025 ('%'): (width=8, offset=78) */
  34. {0xC0, 0xE3, 0x26, 0xED, 0xDB, 0x32, 0x63, 0x01,
  35. 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80},
  36. /* character 0x0026 ('&'): (width=8, offset=94) */
  37. {0x00, 0x6F, 0xFF, 0x90, 0xF4, 0x67, 0x07, 0x04,
  38. 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80},
  39. /* character 0x0027 ('''): (width=8, offset=110) */
  40. {0x00, 0x00, 0x00, 0xE0, 0xE0, 0x00, 0x00, 0x00,
  41. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
  42. {0x00, 0x00, 0x03, 0x0F, 0x1C, 0x10, 0x00, 0x00,
  43. 0x00, 0x00, 0xE0, 0xF8, 0x1C, 0x04, 0x00, 0x00},
  44.
  45. /* character 0x0029 (')'): (width=8, offset=0) */
  46. {0x00, 0x00, 0x10, 0x1C, 0x0F, 0x03, 0x00, 0x00,
  47. 0x00, 0x00, 0x04, 0x1C, 0xF8, 0xE0, 0x00, 0x00},
  48. /* character 0x002A ('*'): (width=8, offset=16) */
  49. {0x00, 0x01, 0x05, 0x07, 0x03, 0x07, 0x05, 0x01,
  50. 0x00, 0x00, 0x40, 0xC0, 0x80, 0xC0, 0x40, 0x00},
  51. /* character 0x002B ('+'): (width=8, offset=32) */
  52. {0x00, 0x01, 0x01, 0x07, 0x07, 0x01, 0x01, 0x00,
  53. 0x00, 0x00, 0x00, 0xC0, 0xC0, 0x00, 0x00, 0x00},
  54. /* character 0x002C (','): (width=8, offset=48) */
  55. {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  56. 0x00, 0x00, 0x00, 0x34, 0x3C, 0x38, 0x00, 0x00},
  57. /* character 0x002D ('-'): (width=8, offset=64) */
  58. {0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x00,
  59. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},
  60. /* character 0x002E ('.'): (width=8, offset=80) */
  61. {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  62. 0x00, 0x00, 0x00, 0x30, 0x30, 0x30, 0x00, 0x00},
  63. /* character 0x002F ('/'): (width=8, offset=96) */
  64. {0x00, 0x00, 0x00, 0x01, 0x07, 0x1E, 0x18, 0x00,
  65. 0x00, 0x18, 0x78, 0xE0, 0x80, 0x00, 0x00, 0x00},
  66. /* character 0x0030 ('0'): (width=8, offset=112) */
  67. {0x00, 0x00, 0x0F, 0x1F, 0x10, 0x16, 0x1F, 0x0F,
  68. 0x00, 0x00, 0xE0, 0xF0, 0xD0, 0x10, 0xF0, 0xE0},
  69. /* character 0x0031 ('1'): (width=8, offset=128) */
  70. {0x00, 0x04, 0x04, 0x0C, 0x1F, 0x1F, 0x00, 0x00,
  71. 0x00, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, 0x00},
  72. /* character 0x0032 ('2'): (width=8, offset=144) */
  73. {0x00, 0x0C, 0x1C, 0x10, 0x11, 0x1F, 0x0E, 0x00,
  74. 0x00, 0x30, 0x70, 0xD0, 0x90, 0x10, 0x10, 0x00},
  75. /* character 0x0033 ('3'): (width=8, offset=160) */
  76. {0x00, 0x0C, 0x1C, 0x11, 0x11, 0x1F, 0x0E, 0x00,
  77. 0x00, 0x60, 0x70, 0x10, 0x10, 0xF0, 0xE0, 0x00},
  78. /* character 0x0034 ('4'): (width=8, offset=176) */
  79. {0x00, 0x00, 0x1F, 0x1F, 0x00, 0x07, 0x07, 0x00,
  80. 0x00, 0xC0, 0xC0, 0x40, 0x40, 0xF0, 0xF0, 0x40},
  81. /* character 0x0035 ('5'): (width=8, offset=192) */
  82. {0x00, 0x1F, 0x1F, 0x11, 0x11, 0x11, 0x10, 0x00,
  83. 0x00, 0x10, 0x10, 0x10, 0x30, 0xE0, 0xC0, 0x00},
  84. /* character 0x0036 ('6'): (width=8, offset=208) */
  85. {0x00, 0x03, 0x07, 0x1E, 0x1A, 0x13, 0x01, 0x00,
  86. 0x00, 0xE0, 0xF0, 0x10, 0x10, 0xF0, 0xE0, 0x00},
  87. /* character 0x0037 ('7'): (width=8, offset=224) */
  88. {0x00, 0x10, 0x10, 0x11, 0x17, 0x1E, 0x18, 0x00,
  89. 0x00, 0x00, 0x70, 0xF0, 0x80, 0x00, 0x00, 0x00},
  90.   /* character 0x0038 ('8'): (width=8, offset=0) */
  91. {0x00, 0x0E, 0x1F, 0x13, 0x11, 0x1F, 0x0E, 0x00,
  92. 0x00, 0xE0, 0xF0, 0x10, 0x90, 0xF0, 0xE0, 0x00},
  93. /* character 0x0039 ('9'): (width=8, offset=16) */
  94. {0x00, 0x0F, 0x1F, 0x10, 0x10, 0x1F, 0x0F, 0x00,
  95. 0x00, 0x00, 0x90, 0xB0, 0xF0, 0xC0, 0x80, 0x00},
  96. /* character 0x003A (':'): (width=8, offset=32) */
  97. {0x00, 0x00, 0x00, 0x06, 0x06, 0x06, 0x00, 0x00,
  98. 0x00, 0x00, 0x00, 0x30, 0x30, 0x30, 0x00, 0x00},
  99. /* character 0x003B (';'): (width=8, offset=48) */
  100. {0x00, 0x00, 0x00, 0x06, 0x06, 0x06, 0x00, 0x00,
  101. 0x00, 0x00, 0x00, 0x34, 0x3C, 0x38, 0x00, 0x00},
  102. /* character 0x003C ('<'): (width=8, offset=64) */
  103. {0x00, 0x01, 0x03, 0x06, 0x0C, 0x18, 0x10, 0x00,
  104. 0x00, 0x00, 0x80, 0xC0, 0x60, 0x30, 0x10, 0x00},
  105. /* character 0x003D ('='): (width=8, offset=80) */
  106. {0x00, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x00,
  107. 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00},
  108. /* character 0x003E ('>'): (width=8, offset=96) */
  109. {0x00, 0x10, 0x18, 0x0C, 0x06, 0x03, 0x01, 0x00,
  110. 0x00, 0x10, 0x30, 0x60, 0xC0, 0x80, 0x00, 0x00},
  111. /* character 0x003F ('?'): (width=8, offset=112) */
  112. {0x00, 0x0C, 0x1C, 0x11, 0x13, 0x1E, 0x0C, 0x00,
  113. 0x00, 0x00, 0x00, 0xB0, 0xB0, 0x00, 0x00, 0x00},
  114. /* character 0x0040 ('@'): (width=8, offset=128) */
  115. {0x0F, 0x1F, 0x10, 0x11, 0x13, 0x12, 0x1F, 0x0F,
  116. 0xE0, 0xF0, 0x10, 0x90, 0xD0, 0x50, 0xD0, 0xD0},
  117. /* character 0x0041 ('A'): (width=8, offset=144) */
  118. {0x7F, 0xFF, 0x88, 0x88, 0xFF, 0x7F
  119. },
  120. /* character 0x0042 ('B'): (width=8, offset=160) */
  121. {0xFF, 0xFF, 0x81, 0x99, 0xDB, 0x7E},
  122. /* character 0x0043 ('C'): (width=8, offset=176) */
  123. {0xFF, 0xFF, 0x81, 0x81, 0xC3, 0xC3},
  124. /* character 0x0044 ('D'): (width=8, offset=192) */
  125. {0xFF, 0xFF, 0xC3, 0xC3, 0x7E, 0x3C},
  126. /* character 0x0045 ('E'): (width=8, offset=208) */
  127. {0xFF, 0xFF, 0xDB, 0xDB, 0xDB, 0xC3},
  128. /* character 0x0046 ('F'): (width=8, offset=224) */
  129. {0xFF, 0xFF, 0x88, 0x88, 0x88, 0x80},
  130. /* character 0x0047 ('G'): (width=8, offset=240) */
  131. {0x7E, 0xFF, 0x81, 0x89, 0xEF, 0x6F},
  132. /* character 0x0048 ('H'): (width=8, offset=256) */
  133. {0xFF, 0xFF, 0x08, 0x08, 0xFF, 0xFF},
  134. /* character 0x0049 ('I'): (width=8, offset=272) */
  135. {0xC3, 0xC3, 0xFF, 0xFF, 0xC3, 0xC3},
  136. /* character 0x004A ('J'): (width=8, offset=288) */
  137. {0x06, 0x07, 0x01, 0x01, 0xFF, 0xFE},
  138. /* character 0x004B ('K'): (width=8, offset=304) */
  139. {0xFF, 0xFF, 0x18, 0x3C, 0x66, 0xC3},
  140. /* character 0x004C ('L'): (width=8, offset=320) */
  141. {0xFF, 0xFF, 0x03, 0x03, 0x03, 0x03},
  142. /* character 0x004D ('M'): (width=8, offset=336) */
  143. {0XFF,0XE0,0X78,0X78,0XE0,0XFF},
  144. /* character 0x004E ('N'): (width=8, offset=352) */
  145. {0xFF, 0xFF, 0x38, 0x1C, 0xFF, 0xFF},
  146.    /* character 0x004F ('O'): (width=8, offset=0) */
  147. {0x7E, 0xFF, 0x81, 0x81, 0xFF, 0x7E},
  148. /* character 0x0050 ('P'): (width=8, offset=16) */
  149. {0xFF, 0xFF, 0xD8, 0xD8, 0xF8, 0xF8},
  150. /* character 0x0051 ('Q'): (width=8, offset=32) */
  151. {0x7E, 0xC3, 0x81, 0x85, 0xC2, 0x7D},
  152. /* character 0x0052 ('R'): (width=8, offset=48) */
  153. {0xFF, 0xFF, 0x88, 0x8C, 0xFF, 0x73},
  154. /* character 0x0053 ('S'): (width=8, offset=64) */
  155. {0x72, 0xF3, 0xDB, 0xDB, 0xCF, 0x46},
  156. /* character 0x0054 ('T'): (width=8, offset=80) */
  157. {0xC0, 0xC0, 0xFF, 0xFF, 0xC0, 0xC0},
  158. /* character 0x0055 ('U'): (width=8, offset=96) */
  159. {0xFE, 0xFF, 0x01, 0x01, 0xFF, 0xFE},
  160. /* character 0x0056 ('V'): (width=8, offset=112) */
  161. {0xF8, 0xFE, 0x07, 0x07, 0xFE, 0xF8},
  162. /* character 0x0057 ('W'): (width=8, offset=128) */
  163. {0xFF, 0x03, 0x3C, 0x3C, 0x03, 0xFF},
  164.    {0x11, 0x0a, 0x04, 0x0a, 0x11},  //X
  165.    {0xC0, 0x60, 0x1F, 0x1F, 0x60, 0xC0},  //Y
  166.    {0XDF,0XDF,0XDF,0XDF,0XDF,0XDF},  //Z
  167.    {0x00, 0x1f, 0x11, 0x11, 0x00},  //
  168.    {0x10, 0x08, 0x04, 0x02, 0x01},  //
  169.    {0x00, 0x11, 0x11, 0x1f, 0x00},  //
  170.    {0x04, 0x08, 0x10, 0x08, 0x04},  //
  171.    {0x01, 0x01, 0x01, 0x01, 0x01},  //
  172.    {0x00, 0x00, 0x10, 0x08, 0x00},  //
  173.    {0x12, 0x15, 0x15, 0x15, 0x0f},  //a
  174.    {0x1f, 0x09, 0x09, 0x09, 0x06},  //b
  175.    {0x0e, 0x11, 0x11, 0x11, 0x0a},  //c
  176.    {0x06, 0x09, 0x09, 0x09, 0x1f},  //d
  177.    {0x0e, 0x15, 0x15, 0x15, 0x0d},  //e
  178.    {0x0f, 0x14, 0x14, 0x10, 0x10},  //f
  179.    {0x09, 0x15, 0x15, 0x15, 0x0e},  //g
  180.    {0x1f, 0x08, 0x08, 0x08, 0x07},  //h
  181.    {0x00, 0x00, 0x17, 0x00, 0x00},  //i
  182.    {0x01, 0x01, 0x01, 0x01, 0x1e},  //j
  183.    {0x1f, 0x04, 0x04, 0x0a, 0x11},  //k
  184.    {0x1e, 0x01, 0x01, 0x01, 0x01},  //l
  185.    {0x0f, 0x10, 0x0f, 0x10, 0x0f},  //m
  186.    {0x1f, 0x10, 0x10, 0x10, 0x0f},  //n
  187.    {0x0e, 0x11, 0x11, 0x11, 0x0e},  //o
  188.    {0x1f, 0x12, 0x12, 0x12, 0x0c},  //p
  189.    {0x0c, 0x12, 0x12, 0x12, 0x1f},  //q
  190.    {0x1f, 0x08, 0x10, 0x10, 0x08},  //r
  191.    {0x09, 0x15, 0x15, 0x15, 0x12},  //s
  192.    {0x1e, 0x09, 0x09, 0x01, 0x02},  //t
  193.    {0x1e, 0x01, 0x01, 0x02, 0x1f},  //u
  194.    {0x18, 0x06, 0x01, 0x06, 0x18},  //v
  195.    {0x1e, 0x01, 0x1e, 0x01, 0x1e},  //w
  196.    {0x1b, 0x04, 0x04, 0x04, 0x1b},  //x
  197.    {0x19, 0x05, 0x05, 0x05, 0x1e},  //y
  198.    {0x11, 0x13, 0x15, 0x19, 0x11},  //z
  199.    {0x00, 0x04, 0x0e, 0x11, 0x00},  //
  200.    {0x00, 0x00, 0x1f, 0x00, 0x00},  //
  201.    {0x00, 0x11, 0x0e, 0x04, 0x00},  //
  202.    {0x08, 0x10, 0x08, 0x04, 0x08},  //
  203.    {0x00, 0x00, 0x00, 0x00, 0x00}   //
  204. };
  205. unsigned char column[41]=
  206. {0
  207.
  208. }; //display memory, cleared before used.
  209. void delayms(unsigned int ms) //just about 1ms
  210. {
  211.    unsigned int n;
  212.    unsigned int i;
  213.    for (n=0; n8) index=1;
  214.
  215.    //column
  216.   tmp1=rowtable[index];
  217.    for (i=1; i<41; i++)
  218.    {
  219.    Cdata=!(column[i] & tmp1);
  220.    Cclock=0;
  221.    Cclock=1;
  222.    }
  223.    //row
  224.    Clatch=0;
  225.    Clatch=1;
  226.    switch (index)
  227.    {
  228.    case 1:
  229.    Row1=0;
  230.    break;
  231.    case 2:
  232.    Row2=0;
  233.    break;
  234.    case 3:
  235.    Row3=0;
  236.    break;
  237.    case 4:
  238.    Row4=0;
  239.    break;
  240.    case 5:
  241.    Row5=0;
  242.    break;
  243.   case 6:
  244.    Row6=0;
  245.    break;
  246.    case 7:
  247.    Row7=0;
  248.    break;
  249.    case 8:
  250.    Row8=0;
  251.    break;
  252.    }
  253.   ET0=1;
  254. }
  255. void LED_put_byte(unsigned int inp)
  256. {
  257.    unsigned char i;
  258.    for (i=1;i<41;i++) column[i]=column[i+1];
  259.   column[40]=inp;
  260. }
  261. void LED_puts(unsigned char *lcd_string)
  262. {
  263.    unsigned char i,tmp_chr;
  264.    while (*lcd_string)
  265.    {
  266.   tmp_chr=*lcd_string;
  267.    for (i=0;i<6;i++)
  268.    {
  269.   LED_put_byte(font[tmp_chr-32][i]);
  270.   delayms(shift_delay);
  271.    }
  272.   LED_put_byte(0); //space between character
  273.   delayms(shift_delay);
  274.   lcd_string++;
  275.    }
  276. }
  277. void main()
  278. {
  279.    unsigned char m[40], i;
  280.   TMOD=0x20; // Timer 1, mode-2 (8-bit auto reload)
  281.   TH1=0xFA; //9600 baud rate
  282.   SCON=0x50;
  283.   TR1=1; //start timer 1
  284.
  285.    /* read 10 bytes or till enter key */
  286.    for (i = 0; i < 240; i++) {
  287.    while (RI == 0); //wait to receive data
  288.    if (SBUF == '\r')
  289.    break;
  290.   m[i] = SBUF; // save value of data
  291.   RI = 0;
  292.    }
  293.   m[i] = '\0';
  294.   init_timer();
  295.   shift_delay=50; //bigger = slower shift
  296.    while(1) {
  297.    // display m
  298.   LED_puts(m);
  299.    }
  300. }
and the attempt does not work on arm
#include <lpc213x.h>
#include <stdio.h>
const unsigned char  font[96][16] =
    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
    0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    unsigned int n;
    unsigned int i;
    for (n=0; n<ms; n++)
        for (i=0; i<100; i++);
void init_timer(void)
__irq void Timer0_IRQ(void);
IODIR0=(1 << 3) | (1 << 4)| (1 << 5)| (1 << 6)| (1 << 7)| (1 << 8)| (1 << 9)| (1 << 10)| (1 << 1)| (1 << 0);
IODIR1|=(1 << 16);
T0PR = 0x00000000;
T0MR0 = 375000L;
T0MCR = 3;
T0TC = 0x00;
T0TCR = 0x00000001;
VICVectAddr4 = (unsigned)Timer0_IRQ;
VICVectCntl4 = (0x20 | 4);
VICIntEnable = (1 << 4);
unsigned int index;
unsigned int i,tmp1;
const unsigned char rowtable[]={0,1,2,4,8,16,32,64,128};
IOSET0|= (1 << 3) | (1 << 4)| (1 << 5)| (1 << 6)| (1 << 7)| (1 << 8)| (1 << 9)| (1 << 10);
index++;
if (index>8) index=1;
IOPIN1=!(column[i] & tmp1);
IOCLR0=(1 << 0);
IOSET0=(1 << 0);
IOCLR0=(1 << 1);
IOSET0=(1 << 1);
switch (index)
case 1: IOPIN0&=(1 << 10);
break;
case 2: IOPIN0&=(1 << 9);
break;
case 3: IOPIN0=(1 << 8);
break;
case 4: IOPIN0=(1 << 7);
break;
case 5: IOPIN0=(1 << 6);
break;
case 6: IOPIN0=(1 << 5);
break;
case 7: IOPIN0=(1 << 4);
break;
case 8: IOPIN0=(1 << 3);
break;
T0IR = (1UL<<0);
VICIntEnable = 0X00;
unsigned char i;
for (i=1;i<41;i++)
column[40]=inp;
void LED_puts(char *lcd_string)
while (*lcd_string)
for (i=0;i<6;i++)
LED_put_byte(0);
lcd_string++;
int main()
init_timer();
shift_delay=100;
LED_puts("8x32 Matrix LED: AT89C2051, 74HC595");
  • Hi Berto,
    Thanks for your question (though I'm not sure you needed to paste _all_ the code in!).
    You might find this document useful from the ARM Information Center: ARM Information Center
    It covers a lot of they issues involved in migrating from 8051 to Cortex-M microcontrollers. I think a lot of the issues you will encounter in your code relate to the way in which 8051 allows you to address individual bits in I/O ports by name. While Cortex-M microcontrollers don't support this in the same way, it's relatively easy to implement using either bitmasks or bit-banding (if your particular microcontroller supports it).
    Hope you find it useful.
    Chris
  • I believe there is no straight forward answer for you question. It will take a certain degree of changes involved in the same. Still it won't be complex process to do that since the logic involves the same.
