In DS-5 Streamline - Timeline View, I know that I can export the .apd file to an Excel sheet.
But, sometimes the data volume is much and if I want to partially save the file, how can I do that?
For example, instead of exporting the whole .apd file, I would like to select the data between say 100ms to 300ms and save it as an Exel sheet.
Does DS-5 support this kind of partial export of profiled data?
Regards
Senthil
For some of the exports you can cut them down by highlighting the active range using the calipers at the top of the timeline view. This changes what is visible on the other tabs, and hence what they export. I'm not entirely sure if it changes what is exported by the timeline tab itself though.
HTH, Pete
Thanks for your feedback. I checked and it works as per my expectation.
