Starting to work in REALVIEW PLATFORM BASEBOARD FOR ARM1176JZF-S ( SOFTWARE ARM DS -5 TOOLS)
I AM WORKING FIRST TIME IN ARM BOARDS. PLEASE GIVE ME THE STEPS OF RUNNING A C PROGRAM IN ARM1176JZF-S WITH ARM DS-5 TOOLS( THE LICENSE OF WHICH I HAVE AND WHICH IS ALREADY INSTALLED IN MY PC ) .I HAVE INSTALLED THE REAL VIEW SOFTWARE PROVIDED IN THE CD WITH THE BOARD. I HAVE BEEN ABLE TO RUN C PROGRAMS  IN ARM FVP ( IN ARM DS-5 TOOLS AND BARE METAL EXAMPLE PROGRAMS AND LINUX BASED PROGRAMS ( IN DS 5 TOOLS) . I HAVE CONNECTED WITH IT THE POWER SUPPLY( RED LED GOT ON) THEN AFTER PRESSING STANDBY BUTTON MANY LEDS TURNED ON. I HAVE CONNECTED TO PORT 1 THE USB( WHICH IS NOT GETTING RECOGNIZED( I. E. NO CHANGE IN MY COMPUTER)).
  • Do you have a DStream or RVI unit?  You'll need one to connect the DS-5 debugger to the board for baremetal debug and image load.
    Assuming you do...  DS-5 has platform support for the PB1176.  So you would create a new target configuration (as you did for the FVP connection), specifying:
      ARM Development Boards --> PB1176JZF-S --> Bare Metal Debug --> Debug ARM1176JZF-S (DAP Enabled)
    As its a "real" board, where it says Connections you will need to select your RVI/DStream unit.
    You don't have to write in all caps
