Am new to this field can any body help me in writing code for embedded web server by using LPC1768(Keil Software). i.e am try to read the data or values from web page to the micro controller,based upon that values am going perform the operation on board.For example in my web page there is on and off buttons to control the operation of the any peripheral connected to the controller.
thank you to all in advance .
In the above question typing mistake not kiel it is a keil software.
Hi, I think you can have a look at mBed implementation.
https://mbed.org/cookbook/HTTP-Server
It implements the networking stack, you can checkout the source code of it.
HI George Wan,
I was got the code from that web page, but am not have any idea in C++.
You mean you don't know how to program in C++? The code on that page is using the Networking Stack for embed. You should have a look at the source code of "networking stack" first. If your board already has networking stack implemented, then you just need a bit socket programming.
HI Sir,
I was posted this one in community also,But am not get any solution for that one that's way i person lay discuss with u sir.I go t the sample code from the Keil web site when i am tried to compile that one am got the this message in build window
Build target 'MCB1700'
custom translating Web.inp...
Custom: C:\Keil\ARM\bin\fcarm @Web\Web.inp
Target not created
to solve this one i was searched in internet, In keil web site also i was saw same error message but different micro controller, they only given one solution for that one.What they provide there is they create the .bin file for the fcarm. Then how can create that fcarm.bin file for that one give me ur valuable suggestion(to me this message also i ws posted in community)
Thank you..
Regards
VIKRAM.
Hello Vikram,
let's get things straight:
Kind regards,
Christopher
HI Mr.Christopher Seidl
Am using version4
http://www.keil.com/download/docs/387.asp this the link have the sample code,
I was used the some code with out any modification then also i was got the same problem.
I was changed the web.inp code only.
Original code
index.htm, keil.gif, nxp_logo.gif, llblue.jpg, pabb.gif, home.png,network.cgi, leds.cgi, tcp.cgi, system.cgi, lcd.cgi, language.cgi,ad.cgi, pg_header.inc, pg_footer.inc, xml_http.js, buttons.cgi,ad.cgx, buttons.cgx To web.c nopr root Web
Changed code by me
FCARM index.htm, keil.gif, nxp_logo.gif, llblue.jpg, pabb.gif, home.png,network.cgi, leds.cgi, tcp.cgi, system.cgi, lcd.cgi, language.cgi,ad.cgi, pg_header.inc, pg_footer.inc, xml_http.js, buttons.cgi,ad.cgx, buttons.cgx To web.c nopr root Web
In this link http://www.keil.com/support/man/docs/uv4/uv4_ut_fcarm.htm the keil provide data about the fcarm after reading this link i changed the original code.
In this link http://www.keil.com/forum/17680/ i was saw same problem but different micro controller there they mention to solve this on they created one .bin file for fcarm.How can create the fcarm.bin file...? if there is any method for creating bin files in keil...? I think If we have the BIN file we can create the HEX file by using BIN2HEX command.Then not only for this one if we want create the bin file for any file what was the method we can use...?
In this link http://www.keil.com/support/man/docs/uv4/uv4_ut_fcarmuv.htm the keil given how to use the FCARM in keil micro-version,They given 4 steps for that one,am not crossing the second step, 2.Change the file type to Image file. You may also change the file compression. For this, use the context menu in the Project window and Options for File.
In my keil i have this option in that window text,custom,lib,c source,c++ source file,assembly language file,object file but i don't have the image file option how can i fix this one in my keil software.
there are multiple problems with this example, but the main problem is: it is for uVision3! It will not compile with uVision4. If you want to test the uV4 HTTP Demo for LPC1700, please open the project under C:\Keil\ARM\Boards\Keil\MCB1700\RL\TCPnet\Http_Demo\Http_demo.uvproj. This can be compiled instantaneously. Remember: You need MDK-Professional to work with Middleware. MDK-Lite (32 kB Code Size limitation) will not work with this example.
I was tried to open project like you told sir (i.e C:\Keil\ARM\Boards\Keil\MCB1700\RL\TCPnet\Http_Demo\Http_demo.uvproj.) then also am getting same message on build window.
Please give me Ur valuable Suggestion to me Sir.
VIKRAM
Hi Sir Mr.Christophe seidl,
Am try to write code for this one by my self with out taking that sample code,
If i want to write code for this one my self what can do(i mean which thing am taker).
For to this one my self i need Ur guidance and valuable suggestion sir.
I hope am get positive response from you sir.
With Regards
do you have MDK-Professional? If not, contact the nearest sales office for an evaluation version. This code will not build without MDK-Professional.
