I would like to develop code for A57 (AARCH64). What toolchain should I use for ARM simulator? can i insert it into DS-5 eclipse enviornment? Is there a eclipse plugin? If not what do I set to build debug in DS-5? what are my options?
Hi MikeB,
See http://www.arm.com/products/tools/development-tools-for-armv8.php
You would need to then contact ARM directly for more info.
Hi Mike,
You could also search the Find a Partner directory. Ways to Search or Filter Company or Products describes the various ways to search. Or you can use the general search bar. Here I did "Cortex-a57 and tool" and then selected "show only content results for Find a Partner at the top". There are more results than shown here.
Happy searching!
Alternatively, there is an AArch64 version of the GCC tool chain available from Linaro. There is nothing to stop you building your code with GCC and debugging with DS-5. But as Ronan mentioned, you will need to contact ARM for the ARMv8-A compatible version of DS-5.
