I would like to develop code for A57 (AARCH64). What toolchain should I use for ARM simulator? can i insert it into DS-5 eclipse enviornment? Is there a eclipse plugin? If not what do I set to build debug in DS-5? what are my options?
Alternatively, there is an AArch64 version of the GCC tool chain available from Linaro. There is nothing to stop you building your code with GCC and debugging with DS-5. But as Ronan mentioned, you will need to contact ARM for the ARMv8-A compatible version of DS-5.
