A question about using CMSIS UART Driver
I'm Japanese sorry about my poor English.
I've recently  been working on MDK-ARM with STM32F103.
I'd like to make a UART program by using cmsis uart driver.
I've done the following procedures.
Is their anything procedure I need ?
(1) I've implemented the following component by using "Manage Run-Time Environment".
    UART(API)
    related components by pressing "Resolve" button.
(2) I've added "main.c" file by selecting "Add New Item to Group" menue.
(3) I've confirmed that
      PLL setting on "system_stm32f10x.c" and "stm32fx.h"
      agree with
      my hardware.
(4) I've set the "Clock Configuration" of "RTE_Defice.h" file
     and
     "RTX Kernel Timer Tick Configuration" of "RTX_Conf_CM.c" file.
(5) At this point,
    I confirmed that
   my "LED Blimking program" based on CMSIS RTOS
   was working properly.
(6) I've added the following codes to "main.c" file.
    #include "Driver_UART.h"                // ::Drivers:UART
    extern ARM_DRIVER_UART Driver_UART1;
   int main (void) {
     osKernelInitialize ();                    // initialize CMSIS-RTOS
     osKernelStart ();                         // start thread execution
     while( Driver_UART1.Configure(115200, 8, ARM_UART_PARITY_NONE, ARM_UART_STOP_BITS_1, ARM_UART_FLOW_CONTROL_NONE) == ARM_UART_ERROR_BAUDRATE ) { }
      uint8_t ch = 'A';
      Driver_UART1.WriteData (&ch, 1);
Sincerely yours
Nagaoka
  • hi, you fail to initialize properly the uart
    take a look at this code:
    ARM_UART_STATUS status;
      status = Driver_UART1.Initialize(NULL, 0);
      status = Driver_UART1.PowerControl(ARM_POWER_FULL);
      status = Driver_UART1.Configure(9600, 8, ARM_UART_PARITY_NONE,
      ARM_UART_STOP_BITS_1,ARM_UART_FLOW_CONTROL_NONE);
      if (status != ARM_UART_OK ) {
      // something go wrong
