__SMLALD() produces suboptimal code
Note: This was originally posted on 19th August 2013 at http://forums.arm.com
__SMLALD() as implemented in core_cm4_simd.h (V3.20) produces suboptimal code (at leas with GCC).
Example:
sample = *samp2_p++; \
re = __SMLALD(ortho_p[COS2_O], sample, re); \
im = __SMLALD(ortho_p[SIN2_O], sample, im); \
ortho_p++;
Produced code [GCC 4.8.1 with -O2 optimization]:
  a94: 4682       mov sl, r0
  a96: f10c 0304  add.w r3, ip, #4
  a9a: f8d4 0100  ldr.w r0, [r4, #256] ; 0x100
  a9e: f8dc c000  ldr.w ip, [ip]
  aa2: fbc0 a8cc  smlald sl, r8, r0, ip
  aa6: 2000       movs r0, #0
  aa8: 9022       str r0, [sp, #136] ; 0x88
  aaa: f8cd 808c  str.w r8, [sp, #140] ; 0x8c
  aae: e9dd 8922  ldrd r8, r9, [sp, #136] ; 0x88
  ab2: f854 0b04  ldr.w r0, [r4], #4
  ab6: ea48 080a  orr.w r8, r8, sl
  aba: fbc0 21cc  smlald r2, r1, r0, ip
  abe: 9125       str r1, [sp, #148] ; 0x94
  ac0: 2100       movs r1, #0
  ac2: 9124       str r1, [sp, #144] ; 0x90
  ac4: e9dd 0124  ldrd r0, r1, [sp, #144] ; 0x90
  ac8: ea40 0002  orr.w r0, r0, r2
  acc: 468a       mov sl, r1
  ace: 4684       mov ip, r0
  ad0: 464a       mov r2, r9
I propose following implementation:
typedef union llreg_u{
  uint32_t w32[2];
  uint64_t w64;
} llreg_t;
__attribute__( ( always_inline ) ) __STATIC_INLINE uint64_t __SMLALD (uint32_t op1, uint32_t op2, uint64_t result)
  llreg_t llr;
  llr.w64 = result;
  __ASM volatile ("smlald %0, %1, %2, %3" : "=r" (llr.w32[0]), "=r" (llr.w32[1]): "r" (op1), "r" (op2) , "0" (llr.w32[0]), "1" (llr.w32[1]) );
  return(llr.w64);
that produces following code [GCC 4.8.1 with -O2 optimization]:
  a96: f109 0504  add.w r5, r9, #4
  a9a: f8d9 c000  ldr.w ip, [r9]
  a9e: f8d3 2100  ldr.w r2, [r3, #256] ; 0x100
  aa2: fbc2 40cc  smlald r4, r0, r2, ip
  aa6: 9a01    ldr r2, [sp, #4]
  aa8: f853 9b04  ldr.w r9, [r3], #4
  aac: fbc9 12cc  smlald r1, r2, r9, ip
Notes:
1. The proposed code assumes little endian but preparation for big endian is trivial.
2. Similar optimization can be applied to __SMLALD() siblings.
Ilija
  • Note: This was originally posted on 22nd August 2013 at http://forums.arm.com
    We've seen issues with GCC not properly handling the M4 intrinsics.   In many cases, the compiler not only doesn't choose the properly instructions, but then runs out of registers and additional overhead is incurred as you save and restore values from the stack.  We've found that the Keil compiler does a much better job with the intrinsics.
    Thanks pointing out issues in GCC. Would do please share cases that can reproduce the failure you described? Your help to improve GCC will be high appreciated.
    - Joey
    - Joey
