CMSIS arm_rms_q15 defect
Note: This was originally posted on 13th July 2012 at http://forums.arm.com
There is a bug in arm_rms_q15 that saturates the sum before dividing for the mean.
00107 /* Truncating and saturating the accumulator to 1.15 format */
00108 sum = __SSAT((q31_t) (sum >> 15), 16);
00109
00110 in1 = (q15_t) (sum / blockSize);
00111
00112 /* Store the result in the destination */
00113 arm_sqrt_q15(in1, pResult);
and
00136 /* Truncating and saturating the accumulator to 1.15 format */
00137 sum = __SSAT((q31_t) (sum >> 15), 16);
00138
00139 in = (q15_t) (sum / blockSize);
00140
00141 /* Store the result in the destination */
00142 arm_sqrt_q15(in, pResult);
should be changed to something like this:
    in = (q31_t) (sum >> 15);
    in1 = __SSAT((in / blockSize), 16);
  • Note: This was originally posted on 19th July 2012 at http://forums.arm.com
    Hi Neanderthal,
    Thanks for reporting this.  You're correct, the original code is incorrectly saturating to 1.15 before doing the divide.  Any reasonable set of data will saturate the result.  Unfortunately, the data used for the regression test is also doing the saturation and didn't catch this bug.  We'll fix this and add to the next release.
    00109
    00111
    and
    00138
    00140
  • Note: This was originally posted on 27th July 2012 at http://forums.arm.com
    Thanks Alban and Paul!
  • Note: This was originally posted on 7th December 2012 at http://forums.arm.com
    I may be wrong but I'm still not satisfied with this fix. I ran this function with small values (1, 2, ... until 181 in q15 format) and got 0 rms. However it works for bigger values. Is this precision loss admitted? I'm investigating...
    I do not understand very well the need to truncate and saturate before dividing and sqrt.
    Please tell me if you see what's wrong.
    Emilien
