So i know this isn't something to do with the board but the debugger configuration in the ARM-DS Ver.2018 software as i implemented this code on Keil MicroVision and it worked properly.I imported the project from Keil and it is getting built properly however when i try executing a new debug hardware connection, it connects the target pro but while executing the flash multiple-load command it throws the following error:
Once this error comes in the command window ,in the progress tab the loading bar just gets stuck on initializing DTSL and does not exit until I pause the debugging.Please someone help me with this problem this occurs when i enable debug from symbol(main) but does not happen when i do it with debug from entry point.
But however when i select the second option after jumping through instructions in the startup file just before it enters main it get stuck on a particular instruction and the command line throws an error like:
Unable to get address/ access to SP
The first highlighted error is the one which is causing the trouble, everytime i try to initiate a new debug connection.
Thank you.
WARNING(TAD451): Errors were found whilst processing CMSIS SVD file "C:\Users\Administrator\Development Studio Workspace\.metadata\.plugins\com.arm.debug.cmsis\DS-MDK\SVD\LPC15xx\LPC15xx.svd". See report "C:\Users\ADMINI~1\AppData\Local\Temp\svd_report3943043305616492283.log" for details.Stopping running target LPC1500_DFP_LPC1549JBD100 on connectionConnected to running target LPC1500_DFP_LPC1549JBD100Execution stopped in Handler mode due to a breakpoint or watchpoint: 0x030002FE0x030002FE B {pc} ; 0x30002fecd "C:\Users\Administrator\Development Studio Workspace"Working directory "C:\Users\Administrator\Development Studio Workspace"Execution stopped in Handler mode at 0x030002FE0x030002FE B {pc} ; 0x30002fereset reset.systemflash load-multiple "C:\Users\Administrator\Development Studio Workspace\Blinky (MCB1500)_LPC1549_Flash\Debug\Blinky (MCB1500)_LPC1549_Flash.axf"ERROR(CMD720-FLP26-FLP6): ! Flash programming failed! Flash programming failed! Verify failed at address: 0x0000001cfile "C:\Users\Administrator\Development Studio Workspace\Blinky (MCB1500)_LPC1549_Flash\Debug\Blinky (MCB1500)_LPC1549_Flash.axf"Execution stopped in Privileged Thread mode due to a breakpoint or watchpoint: 0x0200147C0x0200147C B {pc} ; 0x200147creset reset.systemwaitload "C:\Users\Administrator\Development Studio Workspace\Blinky (MCB1500)_LPC1549_Flash\Debug\Blinky (MCB1500)_LPC1549_Flash.axf"Ignored loads to:0x00000000 ~ 0x0003FFFF (LPC1549JBD100-0)Entry point 0x00000111set debug-from *$ENTRYPOINTstart
Thank you
Efftronics_ARM said: target pro
target properly
