Arm Graphics Analyzer
Can any one help with the usage of Graphics Analyzer?
I have connected host and target using port 5002. Also, in the GA mobile application it is detecting my application as a traceable app. But not able to collect trace data on host.
These are the messages on Console:
[INFO]: Target event: CONNECTION_REQUEST, [com.arm.mgd.core.target.data.DeviceConnectionRequestEventAttachment@6a11c8af]
[INFO]: Target event: AUTHORISATION_REQUEST, [com.arm.mgd.core.target.data.FeatureAuthorisationRequestEventAttachment@60e9a3df]
[INFO]: Target event: DEVICE_INFO, [com.arm.mgd.core.target.data.DeviceInfoEventAttachment@48b65dfb]
  • Hi mgupt,
    It sounds like you are running on Android. The Graphics Analyzer interceptor uses a local domain socket to connect the application being instrumented to the on-target daemon, which is used to package the data for the host machine. In recent versions of the Android SDK, applications are placed inside a more restrictive security sandbox which blocks access to the method we use to create the local domain socket.
    As a workaround for this issue, build the application being tested using a manifest that sets the targetSdkVersion to 25 or lower. We are working on a fix for the next release which should mean that this workaround is no longer required.
    If this doesn't help can you send us a logcat capture of your application (it's more likely that the error is thrown by the interceptor library not the daemon application).
    Kind regards,
    Pete
