Registers not updating in ARM Development Studio
Hi guys,
I am very new to ARM and programming and am taking infantile steps to learn them.
On a windows 10 platform I have downloaded and installed the 30day ARM Dev Studio 2019.0 coding environment together with the FVP (cortex -53Ax1) for emulation.
At this very early stage I am using the default armlink.exe linker.
My aim is to just learn AARCH64 assembly with absolutely no C at all. I have a test code to check registers, memory etc... which is listed below:
.section ".text.boot"
.global _start
_start:
mov X0, #2
Since I am using the default linker I don't know if the sections/directives etc... in the code above matter. It's a very simple piece of code which should just update register X0 to the immediate value 2. However when I check the register X0 it always shows as 0x0000000000000000. If I am correct it must read 0x0000000000000010
Can someone please advise of the correct steps if i am missing out on anything.
Thanks,
Tony201900
