I'm trying out streamline with an FVP model for a bare-metal application. I set up the capture using the Fastline Wizard and select an image with debug symbols. However, I get <unknown code in image.elf> in the Functions and Code view.
Any ideas on what might be wrong?
I previously wrote a blog on how to set this up, if this helps.If you still do not see functions being listed, I would recommend opening a support case with our team to investigate further. Is it possible for you to share the image file used?
