Streamline does not work with the latest gator - any suggestions?
Hello!
I have went through the process of starting the kernel space gator on Raspberry PI3B+. Before that, I was running user space gator with Streamline 5.5.29.1 and this was OK. Now, when I started the Streamline I got an error that the gator is version 680 and that I need to upgrade Streamline. Which I did - to 5.5.29.2 but it still has the same issue.
How can it be that gator is now ahead of the Streamline and the latest versions cannot work together?
Any suggestions on how to circumvent this?
Thanks!
  • Hi Andrej,
    Ronan is correct the problem is that you are using DS-5.29(.x) which is designed to work with gator(5.7). The latest version of gator is now at 6.8.0 and is used with the Arm Development Studio 2018.
    If you are downloading the gator sources from github this will always give you access to the latest version of gator. Instead if you look inside you DS-5 installation you will always find the version of gator that works with your system.
    Gator can be found in: DS-Installation-Directory/sw/streamline/gator
    If you use this gator instead everything should work.
    Hope this helps,
    Stephen
  • Hi Andrej,
    Hope this helps,
    Stephen
