Cortex-A8 NEON strange performance issue
Note: This was originally posted on 10th July 2013 at http://forums.arm.com
Hi all,
As an experienced assembly programmer, I'm currently working on NEON tutorials.
First example done, it beats the original C function by a huge margin :
pld [r1, #64*0]
pld [r1, #64*1]
pld [r1, #64*2]
pld [r1, #64*3]
    ldr  r12, [sp]
    vdup.16 d0, r2 //coeff
    vdup.16 d1, r3 //intercept
1:
        pld  [r1, #64*4]
        vld1.16  {d28-d31}, [r1,:256]!
        vmull.s16   q12, d28, d0[0]
        vmull.s16   q13, d29, d0[0]
        vmull.s16   q14, d30, d0[0]
        vmull.s16   q15, d31, d0[0]
        vaddw.s16   q12, q12, d1
        vaddw.s16   q13, q13, d1
        vaddw.s16   q14, q14, d1
        vaddw.s16   q15, q15, d1
        vqrshrun.s32    d24, q12, #8
        vqrshrun.s32    d25, q13, #8
        vqrshrun.s32    d26, q14, #8
        vqrshrun.s32    d27, q15, #8
        vst1.16  {d24-d27}, [r0,:256]!
        subs    r12, r12, #16
    bgt  1b
    bx      lr
However, there are some pipeline stalls here and there, and the dual-issuing isn't fully in effect. So I decided to optimize it :
pld  [r1, #64*0]
    pld  [r1, #64*1]
    pld  [r1, #64*2]
    pld  [r1, #64*3]
    pld  [r1, #64*4]
    ldr  r12, [sp]
    1:
        vld1.16  {d20-d23}, [r1,:256]!
        vmull.s16   q8, d20, d0[0]
        vmull.s16   q9, d21, d0[0]
        vmull.s16   q10, d22, d0[0]
        vmull.s16   q11, d23, d0[0]
        vaddw.s16   q8, q8, d1
        vaddw.s16   q9, q9, d1
        vaddw.s16   q10, q10, d1
        vaddw.s16   q11, q11, d1
        subs    r12, r12, #32
        vqrshrun.s32    d16, q8, #8
        vqrshrun.s32    d17, q9, #8
        vqrshrun.s32    d18, q10, #8
        ble  2f
        pld  [r1, #64*4]
        vqrshrun.s32    d19, q11, #8
        vst1.16  {d16-d19}, [r0,:256]!
    b 1b
    2:
    bx      lr
There is no pipeline stall at all in this optimized version, and all the memory accessing instructions are surrounded by data processing ones, so they get dual issued twice - at top and bottom. - looks good~
Then the bitter surprise comes while benchmarking on my 4th gen iPod touch and iPhone4 though (iOS6.13 if it matters) : The "optimized" version is about 5% slower than the initial one.
(r12 gets the value of a full HD resolution(1920*1080), and both functions are called several thousand times in a row)
I've been trying several variations, repositioning subs and pld around, nothing matters, the optimized version is ALWAYS slower.
And I removed the pld instruction completely, both functions become much slower as expected, but voila, the optimized version is now about 5% faster.
It seems I did the right thing in removing pipeline stalls and unfolding dual issuing capability, but I must have done something the L2 cache doesn't like in the optimized version.
Can someone give me some insight regarding this? I'm really curious, desperate, frustrated or whatever since without knowing the reason of this strange behavior, all the efforts I put in mastering NEON would be in vain.
Thanks in advance.
  • Note: This was originally posted on 18th July 2013 at http://forums.arm.com
    Yes ARM has released surprisingly little details about the Cortex-A15 CPU. Since the chip is already fully available, I assume they won't release any more info than what is currently in the TRM. Anyway, the Cortex-A15 has various NEON improvements, such as out-of-order & register-renaming of NEON instructions, and dual-issue of some NEON instructions (potentially at the same time as it triple-issues regular CPU instructions and do both a load & store, in other words it can co-issue upto 7 instructions at the same time!).
    I have measured more than 130 GB/s in my NEON code on my quad-core A15, so it certainly is possible!
