Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Software Tools
Jump...
Cancel
Software Tools
Arm Development Studio forum
Cortex M4 fetch Execute program counter functionning
Tools, Software and IDEs blog
Forums
Videos & Files
Help
Jump...
Cancel
New
Replies
Subscribers
126 subscribers
Views
Users
0 members are here
Related
Offline
Gaetan Clavel
over 7 years ago
Note: This was originally posted on 13th May 2013 at http://forums.arm.com
I'm new on this forum and I would like to know some details about the execution of a program on a Cortex M4 ( in a STM32F407 microcontroller). I'm looking for this information because of my studies.
These are my questions :
First I would like to know if there is some kind of predictable execution of the code during the fetch & execute step? It 's quickly mentionned in the user manual and I also read some lines about this in the Cortex A documents but I would like to have some explainations.
I would also like to know how is the program counter (R15 register) functionning? There is a real physical counter which count from 0 to -- when a page is loaded from the flash memory (before to add the value with something else and to store that in R15)? I mean: when I'm reading a page from the flash memory there is a counter which counts 2 by 2 (because of the lengh of the Thumb mnemonics)? If I'm branching far enough to go on another page the counter would return to 0 ? How does it work?
In addition, from a programming point of view, can I choose to write a part of my code at a precise address of the flash memory, and so creating empty areas between 2 parts of code in the flash? Until know I'm writing a lot of "NOP" before to branch....
Finally, all the registers of the Cortex M4 ( R0 to R15 but also the peripheral registers ...) are physicaly situated at the same place? Or the peripheral register are physicaly situated near from the the corresponding peripheral on the chip?
Thank you very much for yours answers and your help!!!!
Offline
Gaetan Clavel
over 7 years ago
Note: This was originally posted on 14th May 2013 at
Thank you for your quick answers!
Do you know how does the predictable execution of the code works? How does the core do to foresee the next code line? Is it different from the more complex µC like the serie of Cortex A.. ?
About the program counter, how does it work to take the next address? if it were a simple counter it would not work because some mnemonics are longer than others and are coded on more than 2 successive addresses...
And concerning the possibility to put a part of the code at a precise address of the flash memory, does someone know if it is possible?
Finally I would like to know if during the reading of the flash memory each page is stored in a buffer before to be treated ?
thank you!
Cancel
Up
0
Down
Cancel
Offline
hao zhang
over 7 years ago
the PC is a 32-bit regeister , it will load the address of the next instruction to be executed and sine it is 32bit , the pc can locate the 4G memory and physicaly designed to do this not software .there are predictable execution of the codes , but it is physically fixed , it is physically designed according to the arm core architecture.all the registers of the Cortex M4 is physicaly put together and the perpherial instrument are connected by the AMBA. the M4 I/O ports can reused to be other function ,so if the function is changed then the registers are far away from the perpherial ,so it is clear the registers are set together.
Cancel
Up
0
Down
Cancel
Offline
hao zhang
over 7 years ago
Note: This was originally posted on 20th May 2013 at
the pc and prefetch are all decided by hardware architecture designed by ARM and have no relationship with software . So prefetch has some differences between cortex m4 and A series ,they are designed for different use.
the buffer is the D/I cache ,all right ? also it is decided by hardware disign , the frequently used data/instruction will be hold in the cache if the cache is full ,then the less used data will be wiped out. the flash is nor/nand flash ? it will be copied into the SRAM ,all the datas processing are in the SRAM ,the buffer is just for high speed data fetch ,just like the prefetch but has different startegy.
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Suggested Answer
How to view SFRs in DS during debugging?
0
1947
views
1
reply
Latest
1 month ago
by
Ronan Synnott
Answered
Dual-core debugging in DS
0
4856
views
2
replies
Latest
1 month ago
by
Ivan Savvateev
Answered
Failure to get an evaluation license with error Unable to execute API call /api/v1/connect
0
5775
views
3
replies
Latest
1 month ago
by
Tim Holt
Suggested Answer
DS52020.0 connection to Musca-A/B boards not working
0
Musca-A
6795
views
4
replies
Latest
1 month ago
by
Daniel Oliveira
Suggested Answer
Positioning a function in a Position Independent Executable for ARMV8
0
7366
views
3
replies
Latest
2 months ago
by
Stephen Theobald
