mmu page table
Note: This was originally posted on 22nd April 2013 at http://forums.arm.com
hi
some question about MMU table.
background:
1.the CPU is ARM1176JS-Z.
2. L1 cache enabled
3.i want to enable MMU in bootloader, to simply it, i only introduce first-level page table.
4. the page table will not be changed after initialization
my question is that:
for the page table itself, where should i put it into? a cacheable area? or a noncacheable area? does MMU hardware access the page table through L1 cache?
both area(cacheable and noncacheable) i have tried, it looks both of them work.
i saw some other code put the page table into noncacheable area , so i want to know if it is must or not.
thanks in advances
BR
PanWei
  • Note: This was originally posted on 23rd April 2013 at http://forums.arm.com
    The MMU can be configured either way, do walks through the L1 data cache or not.
    For systems where you're modifying the tables frequently it can make sense to allow the MMU to do walks through the D cache.  They way its working off the same cached copy as the code is using.
    In your case, with static tables I wouldn't expect it to make much difference either way.  I would probably mark the area as non-cachable and do non-cacheable table walks.  That way I'd avoid polluting the d cache with table descriptors.
    thanks for your reply.
    I am still something confused.
    from the ARM1176JZF-S part  3.2.13. c2, Translation Table Base Register 0, in the last of the part,
    Note
    The ARM1176JZF-S processor cannot page table walk from level one cache.
    so the L1 CACHE will not be used when page table walk. but  in TTB0 , the bit RGN and bit C indicate the cache attributes of  the page table walking. dose these bits apply cache attributes for mmu page table itself.?
    if so, since page table work will not use L1 cache, how can i set  these bits?
    thanks
    Note
    thanks
