Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Announcements
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
Community Help
More
Cancel
Developer Community
Tools and Software
Software Tools
Jump...
Cancel
Software Tools
Arm Development Studio forum
lpc13xx UART
Tools, Software and IDEs blog
Forums
Videos & Files
Help
Jump...
Cancel
New
Replies
Subscribers
126 subscribers
Views
Users
0 members are here
Related
lpc13xx UART
Offline
Frosty Frosty
over 7 years ago
Offline
Frosty Frosty
over 7 years ago
Note: This was originally posted on 10th September 2012 at
http://forums.arm.com
yap I have catch it, was the problem with periferial clock settings. But it takes anothes 2 days to understand what is wrong, because I'm using not keil (uVision) but IAR, ;[
thanks for advice anyway.
Cancel
Up
0
Down
Cancel
Offline
Dhaval Solanki
over 7 years ago
Note: This was originally posted on 8th September 2012 at
Debugg the code and with the help of "UART window" just check if your code works properly. (Debugg using the simulator of your IDE. UART window may be present in the simulator (I don't know what IDE you are using but i use Keil and have a UART window.)
Check the values of all the clocks generated (system clocks, peripheral clocks and baud rate).
If everything is working fine in your code, then check the hardware of your board. Check if the rs232 driver IC is working fine. To ensure this, perform following actions:
1. Just short the Rx & Tx pin (on PC side i.e. input side). Transmit some characters from the terminal and check if you are getting the same on input terminal.
2. If thats ok, then short the Rx & Tx pins (on the CPU side) and transmit some characters and check if you are getting the same on input terminal.
If you haven't found anything yet, then its time to check your serial cable. Just check if the connections are proper. Invert the Rx and Tx of the cable at one connector. and repeat the above steps.
you'll definitely find out where the problem lies.
All the best
Cancel
Up
0
Down
Cancel
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Answered
Link a pure binary file to image with scatter file
0
7134
views
3
replies
Latest
2 months ago
by
Ronan Synnott
Answered
Failed to read contents of Internal RAM L1-I_DATA in ARM DS
0
Cache
Debug and Trace Services Layer (DTSL)
11737
views
23
replies
Latest
2 months ago
by
Boon Khai
Suggested Answer
DS-5 connect fail when cortex-r5 is in lock-step mode
0
9867
views
10
replies
Latest
3 months ago
by
Stuart Hirons
Suggested Answer
On Cortex-M4F microcontrollers: is fixed point math faster or floating point?
0
9601
views
10
replies
Latest
3 months ago
by
Ronan Synnott
Suggested Answer
Debugging kernel: OS support not working for Linux 5.4
0
Kernel Developers
External Hardware Debug
Debugger
8560
views
5
replies
Latest
3 months ago
by
sgoldschmidt
